configuring 871W to bridge wired and wireless, with IPv4 NAT and IPv6 tunnel
matthhal
Hi all,
I was trying to set up an ISR 871W to bridge the wireless and three wired ports, with IPv4 upstream through a DSL bridge, via DHCP and IPv6 upstream via 6in4 tunnel. The DSL bridge passes me the upstream IP with DHCP (2WIRE DMZ setup).
I got pretty close, but when I tried to configure the wired-wireless bridging things quit working for me. The router can ping things fine with IPv4 or IPv6, but the devices in the LAN can only ping the router IP and are incapable of getting to anything else besides that, including traceroute, no hops possible.
Can anybody spot what I must have missed? I'm not as familiar with the ISR products yet.
Matthew.
! Last configuration change at 06:36:31 UTC Fri Mar 29 2013
! NVRAM config last updated at 06:40:00 UTC Fri Mar 29 2013
version 12.3
hostname c871w
boot-start-marker
boot-end-marker
enable secret 5 ...
enable password ...
no aaa new-model
ip subnet-zero
ip cef
ip dhcp excluded-address 192.168.0.1 192.168.0.10
ip dhcp pool inside
   network 192.168.0.0 255.255.255.0
   dns-server 8.8.8.8 8.8.4.4
   default-router 192.168.0.1
ip domain name ...
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip ips po max-events 100
ipv6 unicast-routing
no ftp-server write-enable
bridge irb
interface Tunnel0
no ip address
ipv6 address 2607:.../64
ipv6 mtu 1472
ipv6 virtual-reassembly
tunnel source BVI1
tunnel destination ...
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet0
switchport access vlan 2
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Dot11Radio0
no ip address
broadcast-key change 3600
broadcast-key vlan 1 change 600
encryption mode ciphers tkip
encryption vlan 1 mode ciphers tkip
ssid ...
    vlan 1
    authentication open
    authentication key-management wpa
    wpa-psk ascii 0 ...
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no cdp enable
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
ip nat inside
ip virtual-reassembly
bridge-group 1
interface Vlan2
ip address dhcp
interface BVI1
ip address 192.168.0.1 255.255.255.0
ip nat inside
ipv6 address 2607:...::1/64
ip classless
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Vlan2 overload
access-list 1 permit 192.168.0.0 0.0.255.255
ipv6 route ::/0 Tunnel0
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no modem enable
transport preferred all
transport output all
speed 115200
line aux 0
line vty 0 4
password ...
login
transport input all
scheduler max-task-time 5000
ntp clock-period 17177913
ntp server 131.107.13.100
end
blau grana
Level 7
Level 7
Hello Matthew,
I do not see any static route for IPv4 traffic, do you obtain refault route via DHCP?
Can you ping internet from router?
#ping 8.8.8.8
Can you provide output of these command when you are trying access internet from PC.
#show ip int brief
#show ip route
#show ip nat translation
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
Pinging the upstream default GW and the upstream DNS works fine from IOS, but fails from nodes behind the NAT + Bridge. The setup does work without bridge enabled, but then you can't connect between the wired and wireless segments after that. I'll get the other outputs collected and post them also.
