07-06-2005 05:31 AM - edited 03-02-2019 11:18 PM
I just want to use a 3500 switch as a simple hub. Is this possible, and more importantly, is it simple to set up?
Wanda
07-06-2005 05:40 AM
Yes, you can set the switch as hub by puting all the ports in a single Vlan and disabling spanning tree globally on the switch.
Go to global config mode and use comand " no spanning-tree " or " no spanning-tree vlan 1 "
HTH,
-amit singh
07-06-2005 05:42 AM
Disabling STP and having all ports in one VLAN will not disable MAC learning. There is no way to disable MAC learning on 3500XL switches.
07-06-2005 05:56 AM
Thanks very much for this reply. Forgive my ignorance, but is this significant?
Wanda
07-06-2005 05:59 AM
Yes.. In a hub every port would see all the traffic since there is no concept of maintaining a MAC address table and hence traffic is flooded.
In a switch, since it maintains a MAC address table, all unicast traffic would be only between 2 ports in question. Broadcast/multicast would be still be seen by other ports in the VLAN.
07-06-2005 06:03 AM
Prashanth,
I guess then there is no way for disabling the mac-address learning. I tried to look at the mac-address table aging option but still the least value supported is 10 seconds. So in any case 3500 XL's cannot be configured to disable the mac-address learning.
regards,
-amit singh
07-06-2005 05:41 AM
Yes, you can set the switch as hub by puting all the ports in a single Vlan i.e the default vlan "Vlan 1" and disabling spanning tree globally on the switch.
HTH,
-amit singh
