11-02-2004 04:54 AM - edited 03-02-2019 07:41 PM
Objective: Connecting our Head office from two different locations a) Warehouse b) Facotry. We already working on our head office to our warehouse via leased line but our factory connection via satellite connection.
Scenario 1 : We have our leased line connected from the head office to our warehouse with the current configuration:
User Access Verification
Password:
kudu-hq>en
Password:
Password:
kudu-hq#show run
Building configuration...
Current configuration : 760 bytes
version 12.3
hostname kudu-hq
enable secret xxx
enable password xxx
username xxx password xxx
username nourmaint password xxx
ip subnet-zero
ip cef
interface FastEthernet0
ip address 10.10.1.3 255.255.255.0
speed auto
interface Serial0
bandwidth 128000
ip address 172.17.17.1 255.255.255.252
no fair-queue
interface Serial1
no ip address
shutdown
router rip
version 2
network 10.0.0.0
network 172.17.0.0
network 192.168.0.0
no auto-summary
ip classless
no ip http server
line con 0
line aux 0
line vty 0 4
password xx
login
no scheduler allocate
end
I am putting my emphasis Serial 1, how will i configure the connection since our ISP provide a converter from ethernet port of Alcatel 990NT to the serial 1 connection of our router.
Do you have any idea on how can we resolve this and what configuration do i need to put on the factory router?
If you have any idea please give me a sample configuration for this specific scenario...
11-02-2004 07:10 PM
for the second Link since ur taking ur SP as ur carier better create a GRE tunnel between ur locations and pass on ur traffic over tht.
(considering ur SP providing connecivity on both ur HO and Factory side)
Just add 2 static routes one route on each site .
Default route in ur remote location(factory) router would be thru ur GRE tunnel and the route for ur factory subnets in ur HO would be thru the tunnel.
regds
11-02-2004 11:43 PM
Is there any special configuration from the Head office router that i need to do or same as the warehouse configuration?
Please advise..
Thanks..
11-03-2004 05:30 AM
Theres no specific config as such ..but do find the model config attached below.
HO :
inter ser 0/1
ip address x.x.x.x 255.255.255.252
int tu 0
ip address a.b.c.d 255.255.255.252
tunnel source x.x.x.x
tunnel destination x.x.x.y
ip route q.q.q.q w.w.w.w tunnel 0 (Static for warehouse)
q.q.q.q w.w.w.w = warehouse local lan
but do remember to remove the existing route for warehouse...0
Warehouse :
inter ser 0/0
ip address x.x.x.y 255.255.255.252
inte tunnel 0
ip address a.b.c.e 255.255.255.252
tunnel source x.x.x.y
tunnel destination x.x.x.x
ip route 0.0.0.0 0.0.0.0 tunnel 0 (default traffic from ur local lan towards tunnel)
do remove the existing routes to ur HO from warehouse..
have a look on this link too for ur own benefit..
http://www.cisco.com/en/US/tech/tk827/tk369/tk287/tech_protocol_home.html
hope this would help u out but do get back if u have any queries...
regds
11-11-2004 02:46 AM
Hi! First, you should have specified how the conversion was done because there are several types of converters. But here are some options. If the modem converted ethernet to frame-relay (also uses V.35 serial connector and also seen as serial in the router), you should configure your serial port at both ends as frame-relay with DLCI similar with that configured at the converter. But if the conversion was from ethernet to serial (simple WAN interface that is), the transmission link would be transparent and you'll just have to configure a simple point-to-point connection between your two routers with the bandwidth dependent on the bandwidth provided by the converter. Hope this helps! Thanks - albert Ü
