CSS 11000 routing problem
dlabbadia
I have a CSS 11000 and here's the problem.
Switch IP is 172.16.40.2
Two servers behind the switch with following information
Server1 IP 172.16.40.4
Server2 IP 172.16.40.8
I set up a rule called SURV01.
i set up a virtual ip of 172.16.40.50
I set up two services called Server1 and Server2.
I activated the services.
I added the two services to the rule.
I activated the rule.
the individual servers can be accessed directly from the outside using their direct ips, but the rule isn't working. meaning i can ping 172.16.40.4 and 172.16.40.8 but when i try to ping 172.16.40.50 I get nothing. As well the http requests work individually but not on the virtual.
i have a pix firewall in front of the pix with a static translation for all of the servers as well as the virtual ip. i have icmp allowed as well as http.
there is a line when doing a show ip route that shows
CS50(config)# show ip route
prefix/length next hop if type proto age metric
1.0.0.0/8 1.1.1.1 10 mgmt local -- --
172.16.40.0/24 172.16.40.2 1024 local local 156577 0
CS50(config)#
personally i think this is suppose to be 172.16.40.0 172.16.40.1 noting that my firewall interface is 40.1 and the CSS is 40.2 but I could be wrong and it won't let me change it.
any suggestions would be greatly appreciated.
dave
t.baranski
Level 4
Level 4
Looks like the CSS needs a default route.
