ddr problems
manish-young
Hi there,
i am trying to roubleshoot an isdn remote access, its P-T-P both sides have 800 Series router, all was working fine before shifting lines, after shfting lines
my router call another router get conected but cant router packet , means i cant
ping the remote network,
when i try to use comand (isdn call int bri 0 (number) ), it fails , when i check
show isdn history, it says incoming call failed ,
any ways i am posting the config
with regards
Manish Young
ip subnet-zero
isdn switch-type basic-net3
interface Ethernet0
ip address 192.168.15.45 255.255.255.0
interface BRI0
ip address 192.168.28.5 255.255.255.252
dialer string xxxxxx
dialer-group 1
router rip
network 192.168.15.0
network 192.168.28.0
network 192.168.29.0
no ip http server
ip classless
ip route 192.168.29.0 255.255.255.0 192.168.28.6
dialer-list 1 protocol ip permit
line con 0
stopbits 1
line vty 0 4
password cisco
login
no rcapi server
end
lgijssel
Level 9
Level 9
There are a few things that are odd.
First, you do not seem to use PPP on the ISDN link. (No commands for encapsulation and authentication)
Then, this is a very brief config. Is this really all?
If it stopped working after changing lines, then you might have a wrong dialer number configured on one side or another. You may be behind a PABX and omitted the line-access code. (mostly a zero)
Leo
cymurai
This does not look like a complete config. It looks like you are using dialer profiles, but there are several commands (parts) missing?? Here are some links that might help.
ISDN config:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca71c.html
ISDN 800 config:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca725.html
Dialer Profile config:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1828/products_configuration_guide_chapter09186a008008722c.html
Hope this helps!
