04-18-2002 01:39 AM - edited 03-01-2019 09:21 PM
I am very fresh in this area. Now faced the first challenge! I have users who use asynchronous dial-up connections. Recently some have been complaining that the connections are being terminated with in very few minutes. The error message that I observed from one users laptop is as follows:
100 tty 100 dvschindle Async interface 00:00:00 Modem definitionen for dialup 12 Modems
Apr 18 07:44:56.372: %LINK-5-CHANGED: Interface Async100, changed state to reset
Apr 18 07:44:57.372: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async100, changed state to down
Apr 18 07:45:01.372: %LINK-3-UPDOWN: Interface Async100, changed state to down
The partial out put of sh logg is as follows:
Apr 18 09:16:46.677: TTY130: timer type 1 expired
Apr 18 09:16:46.677: TTY130: Exec timer (continued)
Apr 18 09:17:45.811: As98 DDR: idle timeout
Apr 18 09:17:45.811: As98 DDR: disconnecting call
Apr 18 09:17:45.811: TTY98: Async Int reset: Dropping DTR
Apr 18 09:17:45.827: Modem 3/1 Mica: in modem state TERMINATING
Apr 18 09:17:45.859: Modem 3/1 Mica: in modem state IDLE
Apr 18 09:17:45.903: %ISDN-6-DISCONNECT: Interface Serial2/0:0 disconnected fro
m 008983910 , call lasted 339 seconds
Apr 18 09:17:45.907: Modem 3/1 Mica: DISCONNECT after 00:05:38, due to reason (0
xDF00) Host Disconnect.
Apr 18 09:17:46.679: TTY98: DSR was dropped
Apr 18 09:17:46.679: tty98: Modem: READY->(unknown)
Apr 18 09:17:47.687: TTY98: dropping DTR, hanging up
Apr 18 09:17:47.687: tty98: Modem: HANGUP->(unknown)
Apr 18 09:17:47.811: %LINK-5-CHANGED: Interface Async98, changed state to reset
Apr 18 09:17:48.691: TTY98: cleanup pending. Delaying DTR
Apr 18 09:17:49.691: TTY98: cleanup pending. Delaying DTR
Apr 18 09:17:50.691: TTY98: cleanup pending. Delaying DTR
Apr 18 09:17:50.811: TTY98: no timer type 0 to destroy
Apr 18 09:17:50.811: TTY98: no timer type 1 to destroy
Apr 18 09:17:50.811: TTY98: no timer type 3 to destroy
Apr 18 09:17:50.811: TTY98: no timer type 4 to destroy
Apr 18 09:17:50.811: TTY98: no timer type 2 to destroy
Apr 18 09:17:50.811: Async98: allowing modem_process to continue hangup
Apr 18 09:17:51.691: TTY98: restoring DTR
Apr 18 09:17:52.699: TTY98: autoconfigure probe started
Apr 18 09:17:52.811: %LINK-3-UPDOWN: Interface Async98, changed state to down
Apr 18 09:18:02.812: As98 DDR: re-enable timeout
Apr 18 09:19:24.706: TTY131: timer type 1 expired
Apr 18 09:19:24.706: TTY131: Exec timer (continued)
Can anyone elaborate this problem and direct me in finding a solution.
04-18-2002 08:11 AM
Here is the problem
So you can see the call got disconnected because of idle-timeout has expired..Now Idle-timeout is a "inactivity" timer. By default it is 120 secs. Its good to have "sh run" fron the router but...You can increase tha timer using following interface commands
intercace group-async x
dialer in-band
dialer idle-timeout xxxxx <----xxxx in secs
dialer-group 1
Pl. note that you can enter above commands in any Async interface too.
Now in global config enter following command
dialer-list 1 protocol ip permit
Above config will reset the idle-time to max value (xxxx in secs) everytime any ip packet is passed..
04-18-2002 08:11 AM
Here is the problem
So you can see the call got disconnected because of idle-timeout has expired..Now Idle-timeout is a "inactivity" timer. By default it is 120 secs. Its good to have "sh run" from the router but...You can increase tha timer using following interface commands
dialer in-band
dialer-group 1
