difference between access-group & access-class
athambi
what is the difference between access group and access class commands.Which one is better and under what conditions are each used
leonvd79
Level 4
Level 4
Hello athambi,
access-group [in|out] is used to tie an access-list to an interface.
access-class [in|out] is used to tie an access-list to vty lines.
So in case you want to prevent incoming network traffic on port 80 through Ethernet 0/0 you use
int E0/0
ip access-group 123 in
In case you want to allow only your PC from accessing the VTY via telnet/SSH use
line vty 0 4
ip access-class 1 in
--Leon
* Please rate posts.
leonvd79
Level 4
Level 4
Hello athambi,
int E0/0
line vty 0 4
--Leon
mahmoodmkl
Level 7
Level 7
Access-group is used to bind a access-list with a particular interface.
access-class is used to bind a access-list to VTY lines.
in order to restrict access through telnet.
Mahmood
