E-Mail Attachment problems with VLANs
aherringiii
15 Replies 15
what exactly is the problem ? You cannot send email attachments ? One of the more common solutions would be to adjust the MSS size on your local (V)LAN interfaces, e.g.:
interface FastEthernet0/0
ip tcp adjust-mss 1350
Maybe you can give more details ?
GP
SWITCH 5 CONFIG
Current configuration : 2067 bytes
! Last configuration change at 11:08:52 UTC Fri Dec 30 2005
! NVRAM config last updated at 09:35:03 UTC Fri Dec 30 2005
version 12.1
no service pad
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname xxxxxx
enable secret x $x$xxxx$xxxxxxxxxxxxxxxxxxx
clock timezone UTC -4
clock summer-time EDT recurring
ip subnet-zero
cluster commander-address xxxx.xxxx.xxxx member xx name xxx vlan 1
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
switchport access vlan 16
interface FastEthernet0/10
description FinSol
switchport mode access
interface FastEthernet0/11
description Warranty Title Uplink
switchport access vlan 24
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
description Link from Switch6
interface GigabitEthernet0/2
description Link to Switch4
interface Vlan1
ip address 192.168.xxx.xxx 255.255.255.0
no ip route-cache
ip default-gateway 192.168.xxx.xxx
ip http server
line con 0
exec-timeout 0 0
line vty 0 4
password x xxxxxxxxxxxxxxxxxxxxx
login
line vty 5 15
login
ntp clock-period 17179922
ntp server 192.168.xxx.xxx key 0 prefer
monitor session 1 source interface Gi0/1 - 2
monitor session 1 destination interface Fa0/17
end
FastEthernet0/10 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0012.d9c1.32ca (bia 0012.d9c1.32ca)
Description: FinSol
MTU 1500 bytes, BW 100000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 100BaseTX
input flow-control is unsupported output flow-control is unsupported
Last input never, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 10000 bits/sec, 10 packets/sec
5 minute output rate 10000 bits/sec, 8 packets/sec
703473 packets input, 94188293 bytes, 0 no buffer
Received 245772 broadcasts (0 multicast)
0 watchdog, 192 multicast, 0 pause input
482748 packets output, 305239527 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
User A was moved to a over to a VLAN on our network yesterday, which contains (6) 2950 switches trunked together via the GigabitEthernet ports, routing through a 2801, through a firewall, to a 2600 router and out to the Internet now he's having problems sending E-mail's with attachments larger than 40K. User A can get to the internet fine and use e-mail without attachments, but when sending e-mails with attachments, whether the service is web-based or POP3, the SMTP message time's out.
When
When User A is on the native VLAN he has no problems with E-mail attachments. MTU on both the router and firewall are at default 1500. Even if it was a MTU issue, which I don't think it is, that would effect the native VLAN users as well, or so I would think. Could this be an MSS problem?
We're using an Internet Web Filter so we do use SPAN to monitor ports
Someone stated
"I don't see the other vlans being trunked to the switch. You should trunk your two GIG links"
Even if that is the case, that wouldn't cause this e-mail problem would it?
INTERNAL ROUTER
Current configuration : 4669 bytes
version 12.3
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
boot-start-marker
boot system flash flash:c2801-advipservicesk9-mz.123-11.T3.bin
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 30000 debugging
clock timezone EST -5
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
no ip source-route
ip cef
ip tcp synwait-time 10
no ip bootp server
ip ips po max-events 100
no ftp-server write-enable
description $FW_INSIDE$$ETH-LAN$$INTF-INFO-FE 0$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
speed 100
full-duplex
no cdp enable
no mop enabled
description $ETH-LAN$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
speed 100
full-duplex
no cdp enable
no mop enabled
interface FastEthernet0/1.1
encapsulation dot1Q 1 native
ip address 192.168.10.35 255.255.255.0
no cdp enable
interface FastEthernet0/1.12
encapsulation dot1Q 12
ip address 192.168.12.1 255.255.255.0
ip helper-address 192.168.10.10
no cdp enable
interface FastEthernet0/1.13
encapsulation dot1Q 13
ip address 192.168.13.1 255.255.255.0
no cdp enable
interface FastEthernet0/1.14
encapsulation dot1Q 14
ip address 192.168.14.1 255.255.255.0
no cdp enable
interface FastEthernet0/1.15
encapsulation dot1Q 15
ip address 192.168.15.1 255.255.255.0
no cdp enable
interface FastEthernet0/1.16
encapsulation dot1Q 16
ip address 192.168.16.1 255.255.255.0
no cdp enable
interface FastEthernet0/1.17
encapsulation dot1Q 17
ip address 192.168.17.1 255.255.255.0
no cdp enable
interface FastEthernet0/1.18
encapsulation dot1Q 18
ip address 192.168.18.1 255.255.255.0
no cdp enable
interface FastEthernet0/1.19
encapsulation dot1Q 19
ip address 192.168.19.1 255.255.255.0
no cdp enable
interface FastEthernet0/1.20
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
no cdp enable
interface FastEthernet0/1.21
description PPTE
encapsulation dot1Q 21
ip address 192.168.21.1 255.255.255.0
no cdp enable
interface FastEthernet0/1.22
encapsulation dot1Q 22
ip address 192.168.22.1 255.255.255.0
no cdp enable
interface FastEthernet0/1.23
encapsulation dot1Q 23
ip address 192.168.23.1 255.255.255.0
no cdp enable
interface FastEthernet0/1.24
encapsulation dot1Q 24
ip address 192.168.24.1 255.255.255.0
no cdp enable
interface FastEthernet0/1.25
encapsulation dot1Q 25
ip address 192.168.25.1 255.255.255.0
no cdp enable
interface Serial0/1/0
ip address 192.168.254.1 255.255.255.0
service-module t1 clock source internal
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.10.1
ip route 10.0.0.0 255.255.254.0 192.168.25.2
ip route 172.16.0.0 255.255.0.0 192.168.25.2
ip route 172.16.45.0 255.255.255.0 192.168.254.2
ip route 192.168.11.0 255.255.255.0 192.168.10.200
have you tried to adjust the MSS yet, as suggested in my previous post ? You also might want to try and send pings with different sizes and the DF bit set from the client computer, in order to find out what the largest MTU is:
C:>ping -f -l 1522 www.cisco.com
GP
C:\Documents and Settings\Administrator>ping -f -l 1472 www.yahoo.com
Pinging www.yahoo.akadns.net [216.109.118.78] with 1472 bytes of data:
Reply from 216.109.118.78: bytes=1472 time=40ms TTL=53
Reply from 216.109.118.78: bytes=1472 time=38ms TTL=53
Ping statistics for 216.109.118.78:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 38ms, Maximum = 40ms, Average = 38ms
C:\Documents and Settings\Administrator>ping -f -l 1473 www.yahoo.com
Pinging www.yahoo.akadns.net [216.109.118.79] with 1473 bytes of data:
Packet needs to be fragmented but DF set.
Ping statistics for 216.109.118.79:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Minimum = 0ms, Maximum = 0ms, Average = 0ms
I saw this posted and tried it,
interface Vlan2
I executed the second command, changing the MSS on the FastEthernet ports, but Vlan isn't showing as an option in config t.
OPP(config)#int vlan ?
% Unrecognized command
OPP(config)#int ?
Async Async interface
BVI Bridge-Group Virtual Interface
CDMA-Ix CDMA Ix interface
CTunnel CTunnel interface
Dialer Dialer interface
FastEthernet FastEthernet IEEE 802.3
Group-Async Async Group interface
Lex Lex interface
Loopback Loopback interface
MFR Multilink Frame Relay bundle interface
Multilink Multilink-group interface
Null Null interface
Serial Serial
Tunnel Tunnel interface
Vif PGM Multicast Host interface
Virtual-PPP Virtual PPP interface
Virtual-Template Virtual Template interface
Virtual-TokenRing Virtual TokenRing
range interface range command
OPP(config)#int
No problems downloading e-mail attachments, just attaching them to e-mails, or uploading.
So it's an uploading issue.....
no problem getting data to come down just going up....
All the VLANs are having this same problem.
Using an E-mail client, I tried sending an e-mail with an attachment and got the following message.
"65.x.xxx.xxx (our external router) has too many connections (2) on sccrmhc11"
sccrmhc11 is a service provider e-mail server.
Try removing this command from your router:
no ip tcp synwait-time 10
It looks like the remote mail server is busy or slow for whatever reason and the router is resetting the connection because of this command.
If you have this command on other routers along the path remove it from them as well.
-Mark
I removed the command from both routers, with no results. I also changed the MSS size on the VLAN and the FE ports.
This problem not only occurs with service providers but standard internet mail as well, ie. (Yahoo Mail - can't attach files larger than 20K)
OPP(vlan)#vlan 16 state mtu ?
OPP(vlan)#vlan 16 mtu ?
<1500-18190> Value of VLAN Maximum
OPP(vlan)#vlan 16 mtu 10000
VLAN 16 modified:
MTU 10000
OPP(vlan)#exit
APPLY completed.
Exiting....
OPP#
When I try to attach files to e-mails, the internet browser just times-out.
I'm trying just about anything at this point.
Here are the configs with suggested changes. Someone posted in another discussion that NATIVE VLAN doesn't use dot1q encapsulation, so it's most likely a MTU/MSS problem.
Please look these over and let me know what you think.
