Flow Control & QoS
With Catalyst 3550's when enabling QoS the documentation explicity states that 802.3x flow control MUST be disabled on all ports. There is no explanation why this must be configured (although I can see issues with links pausing etc). What are the technical limitations of this?
I have also been looking for any other information regarding whether this is applicable for Catalyst 6500's as well but I can't find anything. The 6500 QoS documentation does not state anything about flow control.
Slightly confused.....
Andy
Prashanth Krishnappa
The recommendation in a 3550 to turn off flowcontrol with QoS is because when flowcontrol is turned on, and a pause frame is received/transmitted, packets would be discarded irrespective of the packet priority. This can result in higher delays/drops for even the priority packets. It is possible that the expected QoS behavior will not be seen in this case.
I think it is different in a 6500 because each port in 6500 has its own packet buffer on the line card while 3550 has a shared memory in the switching engine.
Hope this helps.
Can anyone point me in the direction of some links on CCO to explain the architechture and the limitations regarding QoS on the 3550 & 2950. Also any links as to why the difference on the 6500 with QoS.
I would have thought that flow-control should be disabled on all switches due to the fact delays could be introduced into the network if a switch 'pauses' on a link?
Andy
