frame-relay command missing on the serial x interface
timur_snoke
I am trying to configure a 3 router setup with frame relay, and i have run into a rather odd problem.
I configured router 1 as the frame relay router (a 2514) to do frame-relay switching.
interface Serial0
no ip address
encapsulation frame-relay
clockrate 2000000
frame-relay lmi-type ansi
frame-relay intf-type dce
frame-relay route 100 interface Serial1 200
interface Serial1
no ip address
clockrate 64000
frame-relay route 200 interface Serial0 100
I configured router 2 to terminate one of the frame-relay end points (a 2501).
interface Serial0
no ip address
interface Serial0.1 point-to-point
frame-relay interface-dlci 100
interface Serial1
no ip address
but when i try to configure the other end point (another 2501) i am unable to use frame-relay commands in the serial interface:
Router_2501b#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Router_2501b(config)#int s0
Router_2501b(config-if)#frame-relay lmi-type ansi
% Invalid input detected at '^' marker.
Router_2501b(config-if)#fra?
fras
i have tried a couple of other routers and i am able to run ospf, bgp, eigrp accross those serial interfaces... but it wont let me configure frame relay on that interface. i have tried other interfaces in that router and totally other routers all to the same effect.
thoughts?
thanks in advance,
-timur
thisisshanky
Level 11
Level 11
Frame-relay will be enabled only if the command
"encapsulation frame-relay" is given. Only after this command is keyed under the interface, does the other commands such as lmi-type, frame-relay map etc will work.
Hope that helps!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
