Help on MRTG Config
nandurisrini
Hi Friends,
I am Facing problem with MRTG Config. any one pl. guide me on proceeding further.. here are the steps I followed on an NT Machine.
1. Configured SNMP Public string with RO on Cisco router.
2. generated mrtg.cfg file in mrtg-2.9.29\bin dir.
3. created www\mrtg is c:\ .
4. installed perl and is working fine getting the Echo Mesg from perl.
5. added new line to script on top enabling the runasdeamon=yes
6. IIS installed on NT.
7. what is the line for Current dir: " is it inetpub\wwroot\mrtg or the one created manually in c:\www\mrtg. here i am having a doubt. should i manually create
the folders or mrtg will create them automatically. Pl let me know.
ALso what is the url i need to type to get the graph interface wise on my roter.
looking expert guidance in this regard. I have gone through MRTG docs but some points are not clear thers. I am working first time on IIS. any one pl. guide me.
Rgds
Srini
leivaae
Srini,
The mrtg.cfg file you just created should look similar the the following lines at the beginning of the file:
# Created by
# cfgmaker public@xxx.xxx.xxx.xxx --global 'WorkDir: c:\www\mrtg' --output mrtg.cfg
### Global Config Options
# for UNIX
# WorkDir: /home/http/mrtg
RunAsDaemon: yes
Interval: 5
# or for NT
Imagedir: c:\www\mrtg\images
That same mrtg.cfg file MUST have the following line at the end:
Hth,
Angel
mkoopsen
Why don't you try your question on the MRTG mailing-list.
http://people.ee.ethz.ch/~oetiker/webtools/mrtg/forum.html
regards,
Martijn
