09-29-2006 01:27 AM - edited 03-03-2019 05:18 AM
We have two PIX 515E firewalls working in HA mode.
I wanted to configure telnet access to firewalls from outside interface.
PIX version is 6.3(5)
I kept PC outside to outside interfaces.
PIX outside IP is 10.10.200.3, inside IP is 10.10.202.5 corresponding virtual IPs are 10.10.200.2 and 10.10.202.7
I have tried following configurations:
pix(config)#telnet 0 0 inside
pix(config)#telnet 0 0 outside
pix(config)#telnet 10.10.200.0 255.255.255.0 outside
pix(config)#telnet 10.10.202.0 255.255.255.0 inside
pix(config)#telnet 10.10.200.200 255.255.255.255 outside
I am able to telnet from internal interface side using inside ip address.
But from outside test pc with IP 10.10.200.200 I am not able to telnet to PIX.
I enabled logging console 5.
when I tried to telnet to outside virtual IP it is not showing any traffic to firewall.
If I try to outside interface I am able to see the traffic like
packets received from source 10.10.200.200 to 10.10.200.3
any help in this configuration. I wanted to telnet firewall from test pc.
SKRAO
Solved! Go to Solution.
09-29-2006 02:05 AM
HI SKRAO,
from security reasons is not possible to telnet to outside interface there is no way how to permit this you need you ssh instead of telnet
here is more info about setting ssh
http://www.ciscopress.com/articles/article.asp?p=25342&seqNum=3&rl=1
M.
Hope that helps rate if it does
09-29-2006 02:05 AM
HI SKRAO,
M.
09-29-2006 06:29 AM
Thanks for your reply.
SKRAO
