help required in Pri e1 network
hi
please check the attached network diagram.this is my setup.
how can i encrypt the data flowing from one network to another,IOs supports encryption.
my router connects to 12 diff locations using e1 links so i want to implement encryption on routers .
anybody pls send me the configuration.
Binoy
6 Replies 6
dbellaze
Level 4
Level 4
Are the E1's private lines, or Internet links? If they are private than I wouldn't worry about encrypting traffic between sites.
Daniel
hi
daniel thanks for the reply
it's purely private line, not connecting to public or internet but customer is worried, he want to implement encryption also.pls give me your views.
Binoy
anybody please send the configuration.
Binoy,
Since these are private links there is no need for encryption. Honestly all that is going to do is create more over administrative over head, and latency due to encryption.
Daniel
Like Daniel suggested you dont need encryption on the link. But some companies enforce extra security (some Banks do encryption of all traffic going between offices)...
You could still do 3des or AES encryption..but it will just add extra overhead on the link..
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
hi
thanks for the information but please send me the configuration.
Binoy
