Help with Booting issue
amakinde
Please find below is what i have don and what am seing when i boot in the my router.System Bootstrap, Version 5.2(5), RELEASE SOFTWARE
Copyright (c) 1986-1994 by cisco Systems
2500 processor with 16384 Kbytes of main memory
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) 3000 Bootstrap Software (IGS-RXBOOT), Version 10.2(5), RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-1995 by cisco Systems, Inc.
Compiled Thu 23-Mar-95 02:08 by kmac
Image text-base: 0x01020000, data-base: 0x00001000
cisco 2500 (68030) processor (revision D) with 16380K/2048K bytes of memory.
Processor board serial number 02095900
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
Authorized for Enterprise software set. (0x0)
1 Ethernet/IEEE 802.3 interface.
2 Serial network interfaces.
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
--- System Configuration Dialog ---
At any point you may enter a question mark '?' for help.
Refer to the 'Getting Started' Guide for additional help.
Use ctrl-c to abort configuration dialog at any prompt.
Default settings are in square brackets '[]'.
Would you like to enter the initial configuration dialog? [yes]: n
Press RETURN to get started!
Router(boot)>en
Router(boot)#copy start run
% Invalid input detected at '^' marker.
Router(boot)#cpoy run
Router(boot)#copy run start
Router(boot)#erase
% Incomplete command.
Router(boot)#reload
Proceed with reload? [confirm]
No usable interfaces
cisco Systems, Inc.
(fc1)
Router(boot)>
Router con0 is now available
Press RETURN to get started.
Router(boot)>en
Router(boot)#erase
Router(boot)#erase flash
System flash directory:
No files in System flash
[0 bytes used, 8388608 available, 8388608 total]
Erase flash device? [confirm]
Are you sure? [yes/no]: y
Erasing device... eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee ...erased
Router(boot)#en
Router(boot)#show version
(fc1)
ROM: System Bootstrap, Version 5.2(5), RELEASE SOFTWARE
Router uptime is 18 minutes
System restarted by power-on
Running default software
Configuration register is 0x2142
Router(boot)#
€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€ø
Router(boot)>copy nvram
Router(boot)>show version
(fc1)
Router uptime is 2 minutes
Configuration register is 0x1402
Router(boot)>reload
Translating "RELOAD"...domain server (255.255.255.255)
% Unknown command or computer name, or unable to find computer address
Router(boot)>sh ver
(fc1)
Router uptime is 6 minutes
Router(boot)>sh run
Router(boot)>en
Password:
Password:
Password:
% Bad secrets
Router(boot)>en
Password:
Password:
% Password timeout expired!
Password:
% Bad secrets
Router(boot)>en
Password:
Password:
Password:
% Bad secrets
Router(boot)>en
Password:
Password:
Password:
% Bad secrets
Router(boot)>en
Password:
Password:
Password:
% Bad secrets
Router(boot)>config t
Router(boot)>\config t
Router(boot)>copy run start
Router(boot)>show st
Router(boot)>show stacks
Minimum process stacks:
Free/Size Name
1572/2000 Init
Interrupt level stacks:
Level Called Free/Size Name
3 0 1000/1000 Serial interface state change interrupt
4 2 932/1000 Network interfaces
5 3475 958/1000 Console Uart
Router(boot)>show context
Router(boot)>?
Exec commands:
connect Open a terminal connection
disconnect Disconnect an existing network connection
enable Turn on privileged commands
exit Exit from the EXEC
help Description of the interactive help system
login Log in as a particular user
logout Exit from the EXEC
name-connection Name an existing network connection
pad Open a X.29 PAD connection
ping Send echo messages
resume Resume an active network connection
show Show running system information
systat Display information about terminal lines
telnet Open a telnet connection
terminal Set terminal line parameters
trace Trace route to destination
where List active connections
x3 Set X.3 parameters on PAD
Router(boot)>sh systat
Router(boot)>sh terminal
Line 1, Location: "", Type: ""
Length: 24 lines, Width: 80 columns
Baud rate (TX/RX) is 9600/9600, no parity, 2 stopbits, 8 databits
Status: Ready, Active
Capabilities: none
Modem state: Ready
Special Chars: Escape Hold Stop Start Disconnect Activation
^^x none - - none
Timeouts: Idle EXEC Idle Session Modem Answer Session Dispatch
0:10:00 never none not set
Session limit is not set.
Time since activation: 0:17:51
Editing is enabled.
History is enabled, history size is 10.
Full user help is disabled
Allowed transports are pad telnet mop. Preferred is telnet.
No output characters are padded
No special data dispatching characters
Modem hardware state: CTS* DSR* DTR RTS
Router(boot)>en
Password:
Password:
Password:
% Bad secrets
Router(boot)>en
Password:
Password:
Password:
% Bad secrets
Router(boot)>en
Password:
Password:
Password:
% Bad secrets
Router(boot)>en
Password:
Password:
Password:
% Bad secrets
Router(boot)>en
Password:
Password:
Password:
% Bad secrets
Router(boot)>o
Translating "O"...domain server (255.255.255.255)
Router(boot)>o/r0x2142
Router(boot)>i
Translating "I"...domain server (255.255.255.255)
Router(boot)>i
Router(boot)>ping 72.22.22.36
% IP protocol not running
Router(boot)>en
Password:
Password:
Password:
% Bad secrets
Router(boot)>write mem
Router(boot)>en
Password: €€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€
€€€€€€€€€€€€€€€€€€€€€€€€€€€ø€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€
Do You Yahoo!?
Yahoo! Sports - Sign up for Fantasy Baseball
scarothe
Greetings:
Looking at your output, it does not appear you have an IOS on the router. A router will go to "boot#" mode when it does not have an IOS in it. When you do a "show flash", does it indicate a file? You will probably have to load a new IOS from your TFTP server.
Steve Carothers/Cisco
Thanks for your reply. See, i have a similar device and copied the ios to a tftp,hopping that, i can then from the device that's not working copy the ios,But ican't get no promt from the router,all i can see is all cccccccccccccccccccc.Please help !!!!!!
to download the soft you can go to the rommon mode.
when the router just begin to boot preess ctrl+break (you should use a good terminal to work: hyperterminal /WIN98 or CRT)
the rommon mode is like the setup of computer there you can change config register or download the soft
Thanks again. I tried that & all i get can is just CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
would you know, if i can use te Aux port?
