Help with nat configuration!!!
webdr
I have a cisco 1700 series router.
I am trying to connect trough a serial device and have not configured nat at all.
All my Ips should route through the serial interface which is 66.65.21.116
so the wan should all traffic coming from the 66.65.21.116 address.
I have a 192.168.0.* ip range in my office.
the lan side of my router fast ethernet 0 is 192.168.0.253
all private ips should route through the wan side of the router.
Please help on how to configure router
fabios
Level 3
Level 3
A very basic configuration that should do for you is:
interface serial 0/0
ip address 66.65.21.116 255.255.255.252 (should be this but check with ISP)
no shutdown
ip nat outside
interface fastethernet 0/0
ip address 192.168.0.253 255.255.255.0
no shutdown
ip nat inside
ip nat inside source list 161 interface serial0/0 overload
access-list 161 permit ip 192.168.0.0 0.0.0.255
ip route 0.0.0.0 0.0.0.0 serial 0/0
