help with the ubr900
thom9834
Can any help me with the installation of this thing.
a.manosca
Level 4
Level 4
Reading and following the documentation should help:
http://www.cisco.com/univercd/cc/td/doc/product/cable/cab_modm/index.htm
Goodluck.
ndoshi
UBr900 is plug and play device , By default it is in bridge mode . So if your isp has registred its mac address you should able to connect .
If you want to put the cable modem in routing mode than check the following url
http://www.cisco.com/pcgi-bin/Support/browse/index.pl?i=Technologies&f=1228
