How can I connect ground cable into 6513 switch ?
cjrchoi11
I'm going to install 6513 switch and have a difficulty to connect Ground cable.
I found a small hole in the chassis(below of slot 13 and above of power supply) and I have a ground package shipped with the switch which includes one grounding lug and two M4 screws. no grounding pad shipped
Can anybody guide me how can I connect the ground cable into the 6513 switch ?
bjellig
Here's a link to the grounding instructions for the 6500:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_installation_guide_chapter09186a008007eb6d.html#1028096
As for the grounding pad, look approximately 2" (5cm) to the right of the hole on the front of the chassis. There is a chassis-colored sticker covering the exposed grounding pad. Peel this off and you will find the 2 mounting holes for the grounding lug.
