How do I add VLANs to switch with native VLAN(not VLAN1)
yeopaul
I am not too sure how to ask this question.
I intend to add some ports of an edge switch to another VLAN, right now the edge switch has only one VLAN(e.g.105) configured as native VLAN.
the edge switch is trunk to the core switch, however, I can see only one native VLAN(e.g.105) allowed on the VTP domain, although the trunk allowed 1-1005 VLANs.
pls see below:
6509-5th-SW1 (enable) sh port trunk 3/2
Port Mode Encapsulation Status Native vlan
3/2 auto negotiate not-trunking 105
Port Vlans allowed on trunk
3/2 1-1005
Port Vlans allowed and active in management domain
3/2 105
Port Vlans in spanning tree forwarding state and not pruned
3/2
Question: How do I configure other VLANs on the switch and add port to it?
6509-5th-SW1 (enable) sh port trunk 3/4
3/4 auto negotiate not-trunking 111
3/4 1-1005
3/4 111
3/4
6509-5th-SW1 (enable) sh spantree 3/2
Port Vlan Port-State Cost Priority Portfast Channel_id
3/2 105 forwarding 4 2 disabled 0
6509-5th-SW1 (enable) sh spantree 3/4
3/4 111 forwarding 4 2 disabled 0
CORE SWITCH Configuration:
begin
#version 5.3(1a)CSX
set password $1$6VNt$eFbGaZITdcN3n0MO/QpLP1
set enablepass $1$fCG/$3UNDnTY5WMHVMK/SWh2AP.
set prompt 6509-5th-SW1
set length 24 default
set logout 20
set banner motd ^C^C
#system
set system baud 9600
set system modem enable
set system name 6509-5th-SW1
set system location 5th Floor ENV Building
set system contact Joe Low
#power
set power redundancy enable
#frame distribution method
set port channel all distribution ip both
#snmp
set snmp community read-only sparrow
set snmp community read-write burung
set snmp community read-write-all secret
set snmp rmon enable
set snmp trap enable module
set snmp trap enable chassis
set snmp trap enable repeater
set snmp trap enable vtp
set snmp trap enable auth
set snmp trap enable ippermit
set snmp trap enable vmps
set snmp trap enable entity
set snmp trap enable config
set snmp trap enable syslog
set snmp trap enable stpx
set snmp trap 10.213.100.133 sparrow
#tacacs+
set tacacs attempts 3
set tacacs directedrequest disable
#radius
set radius deadtime 0
set radius timeout 5
set radius retransmit 2
#authentication
set authentication login tacacs disable console
set authentication login tacacs disable telnet
set authentication enable tacacs disable console
set authentication enable tacacs disable telnet
set authentication login radius disable console
set authentication login radius disable telnet
set authentication enable radius disable console
set authentication enable radius disable telnet
set authentication login local enable console
set authentication login local enable telnet
set authentication enable local enable console
set authentication enable local enable telnet
#vtp
set vtp domain MOE
set vtp mode server
set vtp v2 disable
set vtp pruning disable
set vtp pruneeligible 2-1000
clear vtp pruneeligible 1001-1005
set vlan 1 name default type ethernet mtu 1500 said 100001 state active
set vlan 5 name VLAN0005 type ethernet mtu 1500 said 100005 state active
set vlan 6 name SW3toSW4 type ethernet mtu 1500 said 100006 state active
set vlan 55 name SW1toSW4 type ethernet mtu 1500 said 100055 state active
set vlan 56 name SW2toSW3 type ethernet mtu 1500 said 100056 state active
set vlan 97 name ACE_AS5300 type ethernet mtu 1500 said 100097 state active
set vlan 98 name FTP type ethernet mtu 1500 said 100098 state active
set vlan 99 name AUTO_CAD type ethernet mtu 1500 said 100099 state active
set vlan 103 name VLAN0103 type ethernet mtu 1500 said 100103 state active
set vlan 104 name VLAN0104 type ethernet mtu 1500 said 100104 state active
set vlan 105 name VLAN0105 type ethernet mtu 1500 said 100105 state active
set vlan 106 name VLAN0106 type ethernet mtu 1500 said 100106 state active
set vlan 107 name VLAN0107 type ethernet mtu 1500 said 100107 state active
set vlan 108 name VLAN0108 type ethernet mtu 1500 said 100108 state active
set vlan 109 name VLAN0109 type ethernet mtu 1500 said 100109 state active
set vlan 110 name VLAN0110 type ethernet mtu 1500 said 100110 state active
set vlan 111 name VLAN0111 type ethernet mtu 1500 said 100111 state active
set vlan 112 name VLAN0112 type ethernet mtu 1500 said 100112 state active
set vlan 113 name VLAN0113 type ethernet mtu 1500 said 100113 state active
set vlan 114 name VLAN0114 type ethernet mtu 1500 said 100114 state active
set vlan 115 name VLAN0115 type ethernet mtu 1500 said 100115 state active
set vlan 116 name VLAN0116 type ethernet mtu 1500 said 100116 state active
set vlan 117 name VLAN0117 type ethernet mtu 1500 said 100117 state active
set vlan 118 name VLAN0118 type ethernet mtu 1500 said 100118 state active
set vlan 119 name VLAN0119 type ethernet mtu 1500 said 100119 state active
set vlan 120 name VLAN0120 type ethernet mtu 1500 said 100120 state active
set vlan 121 name VLAN0121 type ethernet mtu 1500 said 100121 state active
set vlan 122 name VLAN0122 type ethernet mtu 1500 said 100122 state active
set vlan 123 name VLAN0123 type ethernet mtu 1500 said 100123 state active
set vlan 124 name VLAN0124 type ethernet mtu 1500 said 100124 state active
set vlan 125 name VLAN0125 type ethernet mtu 1500 said 100125 state active
set vlan 200 name VLAN0200 type ethernet mtu 1500 said 100200 state active
set vlan 1002 name fddi-default type fddi mtu 1500 said 101002 state active
set vlan 1004 name fddinet-default type fddinet mtu 1500 said 101004 state activ
e bridge 0x1 stp ieee
set vlan 1005 name trnet-default type trbrf mtu 1500 said 101005 state active br
idge 0x1 stp ibm
set vlan 1003 name token-ring-default type trcrf mtu 1500 said 101003 state acti
ve parent 0 ring 0x0 mode srb aremaxhop 0 stemaxhop 0
#ip
set interface sc0 1 10.213.100.6/255.255.255.0 10.213.100.255
set interface sc0 up
set interface sl0 0.0.0.0 0.0.0.0
set interface sl0 up
set arp agingtime 1200
set ip redirect enable
set ip unreachable enable
set ip fragmentation enable
set ip route 0.0.0.0/0.0.0.0 10.213.100.1 1
set ip alias default 0.0.0.0
#Command alias
#vmps
set vmps server retry 3
set vmps server reconfirminterval 60
#dns
set ip dns disable
#spantree
#uplinkfast groups
set spantree uplinkfast disable
#backbonefast
set spantree backbonefast disable
#vlan 1
set spantree enable 1
set spantree fwddelay 15 1
set spantree hello 2 1
set spantree maxage 20 1
set spantree priority 8192 1
#vlan 5
set spantree enable 5
set spantree fwddelay 15 5
set spantree hello 2 5
set spantree maxage 20 5
set spantree priority 32768 5
#vlan 6
set spantree enable 6
set spantree fwddelay 15 6
set spantree hello 2 6
set spantree maxage 20 6
set spantree priority 32768 6
#vlan 55
set spantree enable 55
set spantree fwddelay 15 55
set spantree hello 2 55
set spantree maxage 20 55
set spantree priority 32768 55
#vlan 56
set spantree enable 56
set spantree fwddelay 15 56
set spantree hello 2 56
set spantree maxage 20 56
set spantree priority 32768 56
#vlan 97
set spantree enable 97
set spantree fwddelay 15 97
set spantree hello 2 97
set spantree maxage 20 97
set spantree priority 32768 97
#vlan 98
set spantree enable 98
set spantree fwddelay 15 98
set spantree hello 2 98
set spantree maxage 20 98
set spantree priority 32768 98
#vlan 99
set spantree enable 99
set spantree fwddelay 15 99
set spantree hello 2 99
set spantree maxage 20 99
set spantree priority 32768 99
#vlan 103
set spantree enable 103
set spantree fwddelay 15 103
set spantree hello 2 103
set spantree maxage 20 103
set spantree priority 8192 103
#vlan 104
set spantree enable 104
set spantree fwddelay 15 104
set spantree hello 2 104
set spantree maxage 20 104
set spantree priority 8192 104
#vlan 105
set spantree enable 105
set spantree fwddelay 15 105
set spantree hello 2 105
set spantree maxage 20 105
set spantree priority 1 105
#vlan 106
set spantree enable 106
set spantree fwddelay 15 106
set spantree hello 2 106
set spantree maxage 20 106
set spantree priority 8192 106
#vlan 107
set spantree enable 107
set spantree fwddelay 15 107
set spantree hello 2 107
set spantree maxage 20 107
set spantree priority 32768 107
#vlan 108
set spantree enable 108
set spantree fwddelay 15 108
set spantree hello 2 108
set spantree maxage 20 108
set spantree priority 32768 108
#vlan 109
set spantree enable 109
set spantree fwddelay 15 109
set spantree hello 2 109
set spantree maxage 20 109
set spantree priority 32768 109
#vlan 110
set spantree enable 110
set spantree fwddelay 15 110
set spantree hello 2 110
set spantree maxage 20 110
set spantree priority 32768 110
#vlan 111
set spantree enable 111
set spantree fwddelay 15 111
set spantree hello 2 111
set spantree maxage 20 111
set spantree priority 1 111
#vlan 112
set spantree enable 112
set spantree fwddelay 15 112
set spantree hello 2 112
set spantree maxage 20 112
set spantree priority 32768 112
#vlan 113
set spantree enable 113
set spantree fwddelay 15 113
set spantree hello 2 113
set spantree maxage 20 113
set spantree priority 32768 113
#vlan 114
set spantree enable 114
set spantree fwddelay 15 114
set spantree hello 2 114
set spantree maxage 20 114
set spantree priority 32768 114
#vlan 115
set spantree enable 115
set spantree fwddelay 15 115
set spantree hello 2 115
set spantree maxage 20 115
set spantree priority 32768 115
#vlan 116
set spantree enable 116
set spantree fwddelay 15 116
set spantree hello 2 116
set spantree maxage 20 116
set spantree priority 32768 116
#vlan 117
set spantree enable 117
set spantree fwddelay 15 117
set spantree hello 2 117
set spantree maxage 20 117
set spantree priority 32768 117
#vlan 118
set spantree enable 118
set spantree fwddelay 15 118
set spantree hello 2 118
set spantree maxage 20 118
set spantree priority 32768 118
#vlan 119
set spantree enable 119
set spantree fwddelay 15 119
set spantree hello 2 119
set spantree maxage 20 119
set spantree priority 1 119
#vlan 120
set spantree enable 120
set spantree fwddelay 15 120
set spantree hello 2 120
set spantree maxage 20 120
set spantree priority 1 120
#vlan 121
set spantree enable 121
set spantree fwddelay 15 121
set spantree hello 2 121
set spantree maxage 20 121
set spantree priority 1 121
#vlan 122
set spantree enable 122
set spantree fwddelay 15 122
set spantree hello 2 122
set spantree maxage 20 122
set spantree priority 1 122
#vlan 123
set spantree enable 123
set spantree fwddelay 15 123
set spantree hello 2 123
set spantree maxage 20 123
set spantree priority 1 123
#vlan 124
set spantree enable 124
set spantree fwddelay 15 124
set spantree hello 2 124
set spantree maxage 20 124
set spantree priority 1 124
#vlan 125
set spantree enable 125
set spantree fwddelay 15 125
set spantree hello 2 125
set spantree maxage 20 125
set spantree priority 32768 125
#vlan 200
set spantree enable 200
set spantree fwddelay 15 200
set spantree hello 2 200
set spantree maxage 20 200
set spantree priority 32768 200
#vlan 1003
set spantree enable 1003
set spantree fwddelay 15 1003
set spantree hello 2 1003
set spantree maxage 20 1003
set spantree priority 32768 1003
#vlan 1005
set spantree disable 1005
set spantree fwddelay 15 1005
set spantree hello 2 1005
set spantree maxage 20 1005
set spantree priority 32768 1005
#syslog
set logging console enable
set logging server enable
set logging server 10.213.100.52
set logging server 10.213.105.52
set logging server 10.213.100.124
set logging level cdp 4 default
set logging level mcast 2 default
set logging level dtp 5 default
set logging level dvlan 2 default
set logging level earl 2 default
set logging level ip 2 default
set logging level pruning 2 default
set logging level snmp 2 default
set logging level spantree 2 default
set logging level sys 5 default
set logging level tac 2 default
set logging level tcp 2 default
set logging level telnet 2 default
set logging level tftp 2 default
set logging level vtp 2 default
set logging level kernel 2 default
set logging level filesys 2 default
set logging level pagp 5 default
set logging level mgmt 5 default
set logging level mls 5 default
set logging level protfilt 2 default
set logging level security 2 default
set logging level radius 2 default
set logging level udld 4 default
set logging level gvrp 2 default
set logging level cops 2 default
set logging level qos 2 default
set logging level acl 2 default
set logging server facility LOCAL7
set logging server severity 7
set logging buffer 500
set logging timestamp enable
#ntp
set ntp broadcastclient disable
set ntp broadcastdelay 3000
set ntp client enable
set ntp server 10.213.105.2
clear timezone
set summertime disable
#set boot command
set boot config-register 0x2102
set boot system flash bootflash:cat6000-sup.5-3-1a-CSX.bin
#permit list
set ip permit disable
#igmp
set igmp disable
#protocolfilter
set protocolfilter disable
#mls
set mls agingtime 256
set mls agingtime fast 0 0
set mls flow destination
set mls nde version 7
set mls nde disable
#qos
set qos disable
set qos drop-threshold 1q4t rx queue 1 50 60 80 100
set qos map 2q2t tx 1 1 cos 0
set qos map 2q2t tx 1 1 cos 1
set qos map 2q2t tx 1 2 cos 2
set qos map 2q2t tx 1 2 cos 3
set qos map 2q2t tx 2 1 cos 4
set qos map 2q2t tx 2 1 cos 5
set qos map 2q2t tx 2 2 cos 6
set qos map 2q2t tx 2 2 cos 7
set qos drop-threshold 2q2t tx queue 1 80 100
set qos drop-threshold 2q2t tx queue 2 80 100
set qos wrr 2q2t 5 255
set qos txq-ratio 2q2t 80 20
set qos map 1p1q4t rx 1 1 cos 0
set qos map 1p1q4t rx 1 1 cos 1
set qos map 1p1q4t rx 1 2 cos 2
set qos map 1p1q4t rx 1 2 cos 3
set qos map 1p1q4t rx 1 3 cos 4
set qos map 1p1q4t rx 1 3 cos 5
set qos map 1p1q4t rx 2 1 cos 6
set qos map 1p1q4t rx 1 4 cos 7
set qos drop-threshold 1p1q4t rx queue 1 50 60 80 100
set qos map 1p2q2t tx 1 1 cos 0
set qos map 1p2q2t tx 1 1 cos 1
set qos map 1p2q2t tx 1 2 cos 2
set qos map 1p2q2t tx 1 2 cos 3
set qos map 1p2q2t tx 2 1 cos 4
set qos map 1p2q2t tx 2 1 cos 5
set qos map 1p2q2t tx 3 1 cos 6
set qos map 1p2q2t tx 2 2 cos 7
set qos wred 1p2q2t tx queue 1 80 100
set qos wred 1p2q2t tx queue 2 80 100
set qos wrr 1p2q2t 5 255
set qos txq-ratio 1p2q2t 70 15 15
set qos bridged-microflow-policing disable 1-1000
set qos cos-dscp-map 0 8 16 24 32 40 48 56
set qos ipprec-dscp-map 0 8 16 24 32 40 48 56
set qos dscp-cos-map 0-7:0
set qos dscp-cos-map 8-15:1
set qos dscp-cos-map 16-23:2
set qos dscp-cos-map 24-31:3
set qos dscp-cos-map 32-39:4
set qos dscp-cos-map 40-47:5
set qos dscp-cos-map 48-55:6
set qos dscp-cos-map 56-63:7
set qos policed-dscp-map 0:0
set qos policed-dscp-map 1:1
set qos policed-dscp-map 2:2
set qos policed-dscp-map 3:3
set qos policed-dscp-map 4:4
set qos policed-dscp-map 5:5
set qos policed-dscp-map 6:6
set qos policed-dscp-map 7:7
set qos policed-dscp-map 8:8
set qos policed-dscp-map 9:9
set qos policed-dscp-map 10:10
set qos policed-dscp-map 11:11
set qos policed-dscp-map 12:12
set qos policed-dscp-map 13:13
set qos policed-dscp-map 14:14
set qos policed-dscp-map 15:15
set qos policed-dscp-map 16:16
set qos policed-dscp-map 17:17
set qos policed-dscp-map 18:18
set qos policed-dscp-map 19:19
set qos policed-dscp-map 20:20
set qos policed-dscp-map 21:21
set qos policed-dscp-map 22:22
set qos policed-dscp-map 23:23
set qos policed-dscp-map 24:24
set qos policed-dscp-map 25:25
set qos policed-dscp-map 26:26
set qos policed-dscp-map 27:27
set qos policed-dscp-map 28:28
set qos policed-dscp-map 29:29
set qos policed-dscp-map 30:30
set qos policed-dscp-map 31:31
set qos policed-dscp-map 32:32
set qos policed-dscp-map 33:33
set qos policed-dscp-map 34:34
set qos policed-dscp-map 35:35
set qos policed-dscp-map 36:36
set qos policed-dscp-map 37:37
set qos policed-dscp-map 38:38
set qos policed-dscp-map 39:39
set qos policed-dscp-map 40:40
set qos policed-dscp-map 41:41
set qos policed-dscp-map 42:42
set qos policed-dscp-map 43:43
set qos policed-dscp-map 44:44
set qos policed-dscp-map 45:45
set qos policed-dscp-map 46:46
set qos policed-dscp-map 47:47
set qos policed-dscp-map 48:48
set qos policed-dscp-map 49:49
set qos policed-dscp-map 50:50
set qos policed-dscp-map 51:51
set qos policed-dscp-map 52:52
set qos policed-dscp-map 53:53
set qos policed-dscp-map 54:54
set qos policed-dscp-map 55:55
set qos policed-dscp-map 56:56
set qos policed-dscp-map 57:57
set qos policed-dscp-map 58:58
set qos policed-dscp-map 59:59
set qos policed-dscp-map 60:60
set qos policed-dscp-map 61:61
set qos policed-dscp-map 62:62
set qos policed-dscp-map 63:63
set qos acl default-action ip dscp 0
set qos acl default-action ipx dscp 0
set qos acl default-action mac dscp 0
set qos policy-source local
set cops retry-interval 30 30 300
set qos rsvp disable
set qos rsvp policy-timeout 30
set qos rsvp local-policy forward
#vlan mapping
#gmrp
set gmrp disable
#garp
set garp timer join 200
set garp timer leave 600
set garp timer leaveall 10000
#CDP
set cdp interval 60
set cdp holdtime 180
set cdp enable
#UDLD
set udld disable
#Port Channel
set port channel 2/5-8 74
set port channel 3/1-4 75
set port channel 3/5-8 76
set port channel 4/1-4 77
set port channel 4/5-8 78
set port channel 1/1-2 128
set port channel 2/3-4 130
set port channel 2/1-2 174
#Security ACLs
clear security acl all
commit security acl all
#Local Director Acceleration
set lda disable
#module 1 : 2-port 1000BaseX Supervisor
set module name 1
set vlan 5 1/1-2
set port enable 1/1-2
set port trap 1/1-2 enable
set port name 1/1-2
set port security 1/1-2 disable
set port broadcast 1/1-2 100%
set port membership 1/1-2 static
set port protocol 1/1-2 ip on
set port protocol 1/1-2 ipx auto
set port protocol 1/1-2 group auto
set port negotiation 1/1-2 enable
set port flowcontrol 1/1-2 send desired
set port flowcontrol 1/1-2 receive off
set cdp enable 1/1-2
set udld enable 1/1-2
set trunk 1/1 on dot1q 1-1005
set trunk 1/2 on dot1q 1-1005
set spantree portfast 1/1-2 disable
set spantree portcost 1/1-2 4
set spantree portpri 1/1-2 32
set spantree portvlanpri 1/1 0
set spantree portvlanpri 1/2 0
set spantree portvlancost 1/1 cost 3
set spantree portvlancost 1/2 cost 3
set port qos 1/1-2 cos 0
set port qos 1/1-2 trust untrusted
set port qos 1/1-2 port-based
set port qos 1/1-2 policy-source cops
set port rsvp 1/1-2 dsbm-election disable 128
set port gvrp 1/1-2 disable
set gvrp registration normal 1/1-2
set gvrp applicant normal 1/1-2
set port gmrp 1/1-2 enable
set gmrp registration normal 1/1-2
set gmrp fwdall disable 1/1-2
set port channel 1/1-2 mode on
set port jumbo 1/1 disable
set port jumbo 1/2 disable
#module 2 : 8-port 1000BaseX Ethernet
set module name 2
set module enable 2
set vlan 1 2/1-2,2/5-8
set vlan 5 2/3-4
set port enable 2/1-8
set port trap 2/1-8 enable
set port name 2/5 5thFloor 4912 Seg100
set port name 2/6 4912 spare
set port name 2/7 100Seg 3524-1
set port name 2/8 100Seg 3524-2
set port name 2/1-4
set port security 2/1-8 disable
set port broadcast 2/1-8 100%
set port membership 2/1-8 static
set port protocol 2/1-8 ip on
set port protocol 2/1-8 ipx auto
set port protocol 2/1-8 group auto
set port negotiation 2/1-8 enable
set port flowcontrol 2/1-8 send desired
set port flowcontrol 2/1-8 receive off
set cdp enable 2/1-8
set udld enable 2/1-5,2/7-8
set udld disable 2/6
set trunk 2/1 on dot1q 1-1005
set trunk 2/2 on dot1q 1-1005
set trunk 2/3 on dot1q 1-1005
set trunk 2/4 on dot1q 1-1005
set trunk 2/5 auto negotiate 1-1005
set trunk 2/6 auto negotiate 1-1005
set trunk 2/7 auto negotiate 1-1005
set trunk 2/8 auto negotiate 1-1005
set spantree portfast 2/1-8 disable
set spantree portcost 2/1-8 4
set spantree portpri 2/5-8 32
set spantree portpri 2/1-4 60
set spantree portvlanpri 2/1 0
set spantree portvlanpri 2/2 0
set spantree portvlanpri 2/3 0
set spantree portvlanpri 2/4 0
set spantree portvlanpri 2/5 0
set spantree portvlanpri 2/6 0
set spantree portvlanpri 2/7 0
set spantree portvlanpri 2/8 0
set spantree portvlancost 2/1 cost 3
set spantree portvlancost 2/2 cost 3
set spantree portvlancost 2/3 cost 3
set spantree portvlancost 2/4 cost 3
set spantree portvlancost 2/5 cost 3
set spantree portvlancost 2/6 cost 3
set spantree portvlancost 2/7 cost 3
set spantree portvlancost 2/8 cost 3
set port qos 2/1-8 cos 0
set port qos 2/1-8 trust untrusted
set port qos 2/1-8 port-based
set port qos 2/1-8 policy-source cops
set port rsvp 2/1-8 dsbm-election disable 128
set port gvrp 2/1-8 disable
set gvrp registration normal 2/1-8
set gvrp applicant normal 2/1-8
set port gmrp 2/1-8 enable
set gmrp registration normal 2/1-8
set gmrp fwdall disable 2/1-8
set port channel 2/1-4 mode on
set port channel 2/5-8 mode auto silent
set port jumbo 2/1 disable
set port jumbo 2/2 disable
set port jumbo 2/3 disable
set port jumbo 2/4 disable
set port jumbo 2/5 disable
set port jumbo 2/6 disable
set port jumbo 2/7 disable
set port jumbo 2/8 disable
#module 3 : 8-port 1000BaseX Ethernet
set module name 3
set module enable 3
set vlan 104 3/1
set vlan 105 3/2
set vlan 106 3/3
set vlan 111 3/4
set vlan 119 3/5
set vlan 120 3/6
set vlan 121 3/7
set vlan 122 3/8
set port enable 3/1-8
set port trap 3/1-8 enable
set port name 3/1 Segment 104
set port name 3/2 5thFloor Segment
set port name 3/3 6thFloor Seg106
set port name 3/4 11thFloor Seg111
set port name 3/5 19thFloor Seg119
set port name 3/6 20thFloor Seg120
set port name 3/7 21thFloor Seg121
set port name 3/8 22ndFloor Seg122
set port security 3/1-8 disable
set port broadcast 3/1-8 100%
set port membership 3/1-8 static
set port protocol 3/1-8 ip on
set port protocol 3/1-8 ipx auto
set port protocol 3/1-8 group auto
set port negotiation 3/1-8 enable
set port flowcontrol 3/1-8 send desired
set port flowcontrol 3/1-8 receive off
set cdp enable 3/1-8
set udld enable 3/1-8
set trunk 3/1 auto negotiate 1-1005
set trunk 3/2 auto negotiate 1-1005
set trunk 3/3 auto negotiate 1-1005
set trunk 3/4 auto negotiate 1-1005
set trunk 3/5 auto negotiate 1-1005
set trunk 3/6 auto negotiate 1-1005
set trunk 3/7 auto negotiate 1-1005
set trunk 3/8 auto negotiate 1-1005
set spantree portfast 3/1-8 disable
set spantree portcost 3/1-8 4
set spantree portpri 3/1-8 2
set spantree portvlanpri 3/1 1
set spantree portvlanpri 3/2 0
set spantree portvlanpri 3/3 0
set spantree portvlanpri 3/4 0
set spantree portvlanpri 3/5 0
set spantree portvlanpri 3/6 0
set spantree portvlanpri 3/7 0
set spantree portvlanpri 3/8 0
set spantree portvlancost 3/1 cost 3
set spantree portvlancost 3/2 cost 3
set spantree portvlancost 3/3 cost 3
set spantree portvlancost 3/4 cost 3
set spantree portvlancost 3/5 cost 3
set spantree portvlancost 3/6 cost 3
set spantree portvlancost 3/7 cost 3
set spantree portvlancost 3/8 cost 3
set port qos 3/1-8 cos 0
set port qos 3/1-8 trust untrusted
set port qos 3/1-8 port-based
set port qos 3/1-8 policy-source cops
set port rsvp 3/1-8 dsbm-election disable 128
set port gvrp 3/1-8 disable
set gvrp registration normal 3/1-8
set gvrp applicant normal 3/1-8
set port gmrp 3/1-8 enable
set gmrp registration normal 3/1-8
set gmrp fwdall disable 3/1-8
set port channel 3/1-8 mode auto silent
set port jumbo 3/1 disable
set port jumbo 3/2 disable
set port jumbo 3/3 disable
set port jumbo 3/4 disable
set port jumbo 3/5 disable
set port jumbo 3/6 disable
set port jumbo 3/7 disable
set port jumbo 3/8 disable
#module 4 : 8-port 1000BaseX Ethernet
set module name 4
set module enable 4
set vlan 1 4/4-8
set vlan 103 4/3
set vlan 123 4/1
set vlan 124 4/2
set port enable 4/1-8
set port trap 4/1-8 enable
set port name 4/1 23ndFloor Seg123
set port name 4/2 24thFloor Seg124
set port name 4/3 Annex Seg103
set port name 4/4-8
set port security 4/1-8 disable
set port broadcast 4/1-8 100%
set port membership 4/1-8 static
set port protocol 4/1-8 ip on
set port protocol 4/1-8 ipx auto
set port protocol 4/1-8 group auto
set port negotiation 4/1-8 enable
set port flowcontrol 4/1-8 send desired
set port flowcontrol 4/1-8 receive off
set cdp enable 4/1-8
set udld enable 4/1-3
set udld disable 4/4-8
set trunk 4/1 auto negotiate 1-1005
set trunk 4/2 auto negotiate 1-1005
set trunk 4/3 auto negotiate 1-1005
set trunk 4/4 auto dot1q 1-1005
set trunk 4/5 auto negotiate 1-1005
set trunk 4/6 auto negotiate 1-1005
set trunk 4/7 auto negotiate 1-1005
set trunk 4/8 auto isl 1-1005
set spantree portfast 4/1-8 disable
set spantree portcost 4/1-8 4
set spantree portpri 4/1-8 32
set spantree portvlanpri 4/1 0
set spantree portvlanpri 4/2 0
set spantree portvlanpri 4/3 0
set spantree portvlanpri 4/4 0
set spantree portvlanpri 4/5 0
set spantree portvlanpri 4/6 0
set spantree portvlanpri 4/7 0
set spantree portvlanpri 4/8 0
set spantree portvlancost 4/1 cost 3
set spantree portvlancost 4/2 cost 3
set spantree portvlancost 4/3 cost 3
set spantree portvlancost 4/4 cost 3
set spantree portvlancost 4/5 cost 3
set spantree portvlancost 4/6 cost 3
set spantree portvlancost 4/7 cost 3
set spantree portvlancost 4/8 cost 3
set port qos 4/1-8 cos 0
set port qos 4/1-8 trust untrusted
set port qos 4/1-8 port-based
set port qos 4/1-8 policy-source cops
set port rsvp 4/1-8 dsbm-election disable 128
set port gvrp 4/1-8 disable
set gvrp registration normal 4/1-8
set gvrp applicant normal 4/1-8
set port gmrp 4/1-8 enable
set gmrp registration normal 4/1-8
set gmrp fwdall disable 4/1-8
set port channel 4/1-8 mode auto silent
set port jumbo 4/1 disable
set port jumbo 4/2 disable
set port jumbo 4/3 disable
set port jumbo 4/4 disable
set port jumbo 4/5 disable
set port jumbo 4/6 disable
set port jumbo 4/7 disable
set port jumbo 4/8 disable
#module 5 empty
#module 6 empty
#module 7 empty
#module 8 empty
#module 9 empty
#module 15 : 1-port Multilayer Switch Feature Card
set module name 15
set module enable 15
set vlan 1 15/1
set port enable 15/1
set port name 15/1
set cdp enable 15/1
set trunk 15/1 nonegotiate isl 1-1005
set spantree portcost 15/1 4
set spantree portpri 15/1 32
set spantree portvlanpri 15/1 0
set spantree portvlancost 15/1 cost 3
set port rsvp 15/1 dsbm-election disable 128
set port gmrp 15/1 enable
set gmrp registration normal 15/1
set gmrp fwdall disable 15/1
#module 16 empty
#switch port analyzer
#cam
set cam agingtime 1,5-6,55-56,97-99,103-125,200,1003,1005 300
#gvrp
set gvrp dynamic-vlan-creation disable
set gvrp disable
end
EDGE SWITCH Configuration:
hostname L5ES4
aaa new-model
aaa authentication login default local
enable password 7 <removed>
username admin1 password 7 <removed>
username admin2 password 7 <removed>
ip subnet-zero
stackmaker name 5th-floor
interface FastEthernet0/1
spanning-tree portfast
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface VLAN1
ip address 10.213.105.14 255.255.255.0
no ip directed-broadcast
no ip route-cache
logging trap notifications
logging 10.213.100.124
snmp-server engineID local 0000000902000004DD403640
snmp-server community <removed> RO
snmp-server community <removed> RW
snmp-server chassis-id 0x12
line con 0
transport input none
stopbits 1
line vty 0 4
line vty 5 15
ntp clock-period 11259547
ntp peer 10.213.105.2
end
L5ES4#sh vlan
VLAN Name Status Ports
1 default active Fa0/1, Fa0/2, Fa0/3, Fa0/4,
Fa0/5, Fa0/6, Fa0/7, Fa0/8,
Fa0/9, Fa0/10, Fa0/11, Fa0/12,
Fa0/13, Fa0/14, Fa0/15, Fa0/16,
Fa0/17, Fa0/18, Fa0/19, Fa0/20,
Fa0/21, Fa0/22, Fa0/23, Fa0/24,
Gi0/1, Gi0/2
99 VLAN0099 active
1002 fddi-default active
1003 token-ring-default active
1004 fddinet-default active
1005 trnet-default active
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 1002 1003
99 enet 100099 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 1 1003
1003 tr 101003 1500 1005 0 - - srb 1 1002
1004 fdnet 101004 1500 - - 1 ibm - 0 0
1005 trnet 101005 1500 - - 1 ibm - 0 0
L5ES4#sh vtp st
VTP Version : 2
Configuration Revision : 1
Maximum VLANs supported locally : 254
Number of existing VLANs : 6
VTP Operating Mode : Server
VTP Domain Name :
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
MD5 digest : 0x9C 0x0A 0x5A 0x3B 0x83 0xC7 0xA6 0xDE
Configuration last modified by 10.213.105.14 at 5-6-02 17:26:18
6 Replies 6
bsivasub
Level 4
Level 4
Hi bsivasub,
for each edge switch, only one VLAN is configured. From the core switch, I can see this command:
set vlan 3/2 105
set trunk 3/2 nonegotiate dot1q 1-1005
however, why is it that I can't see the port in trunking mode?
3/2 1-1005
3/2 105
3/2
On the edge switch, When I do a show VLAN, I can see the VLAN 105. but the switchport is not configured with :
switchport mode access vlan.....
switchport mode trunk....
Is it because the switch is in native vlan 105, therefore there is no need to configure per port vlan assignment?
I have this problem when I add in another VLAN --- vlan database, vlan...etc, the whole switch hung..
Paul
The trunk between the 6500 and the XL is not up
http://www.cisco.com/warp/public/473/43.html
The trunking mode on the 6500 is currently auto on 3/2. Change is to nonegotiate
Under the XL gig interface
switchport trunk encapsulation dot1q (if you decide to do ISL, use ISL)
If you use dot1q, make sure the native VLAN matches on both switches
-Prashanth
Hi Prashanth,
Thanks for the pointer.
When I set the gig port to trunk, the switch actually hung. Show VTP stat on the XL shows that it is in Server mode. The core switch is also in VTP server mode. would that result in VTP info to propagate back to the core? and causing the switches to hung? Can I, in this case, set the switch to transparent mode, and assign VLANs accordingly?
rgds,
Paul
Yes. It is always safe to use transparent VTP mode while introducing a new switch. Make sure you create the VLANs locally in the VLAN database
-Prashanth
Thanks Prashanth.
