how does a switch learn its route
dan_track
I have a cisco switch and somehow it finds the best route through different routers, I tested this with traceroute from the switch. How does the switch learn these routes?
Dan
13 Replies 13
Richard Burts
Dan
We might be able to give better answers if we knew more about your situation. In particular it would help if we knew whether this is a layer 2 switch or if it is one of the switches with both layer 2 and layer 3 capability. If the switch is layer 3 capable then it may be running a routing protocol and making its own routing decisions.
If it is a layer 2 switch then the switch is configured with a default gateway and it will always forward traffic to remote destinations by forwarding to the default gateway. Of course after the traffic gets to the default gateway it maigh take different paths depending on the forwarding decision made by the default gateway.
Rick
Rick
Hi Rick
Thanks for the info. My switch is a 3500 layer 2 switch. Here's the config for my switch:
Current configuration:
! Last configuration change at 16:04:28 GMT Wed Mar 15 2006
! NVRAM config last updated at 09:49:35 GMT Wed Apr 27 2005
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname switch1
enable secret 5 ttttttttttt
clock timezone GMT 1
ip subnet-zero
ip name-server 10.11.10.2
ip name-server 10.11.10.1
cluster enable l3 0
cluster member 1 mac-address 0007.ebc9.9380
cluster member 2 mac-address 0007.ebc9.94c0
cluster member 3 mac-address 0007.853f.6d00
interface FastEthernet0/1
switchport access vlan 102
interface FastEthernet0/2
duplex full
speed 100
port monitor FastEthernet0/8
switchport access vlan 110
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
port monitor FastEthernet0/19
port monitor FastEthernet0/22
switchport access vlan 100
interface FastEthernet0/6
switchport access vlan 101
interface FastEthernet0/7
duplex full
speed 100
interface FastEthernet0/8
duplex full
speed 100
interface FastEthernet0/9
duplex full
speed 100
interface FastEthernet0/10
duplex full
speed 100
interface FastEthernet0/11
duplex full
speed 100
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
duplex full
speed 100
port monitor FastEthernet0/23
interface FastEthernet0/15
duplex full
speed 100
interface FastEthernet0/16
duplex full
speed 100
switchport access vlan 108
interface FastEthernet0/17
duplex full
speed 100
interface FastEthernet0/18
duplex full
speed 100
interface FastEthernet0/19
duplex full
speed 100
interface FastEthernet0/20
duplex full
speed 100
switchport trunk native vlan 108
switchport mode trunk
interface FastEthernet0/21
duplex full
speed 100
port monitor FastEthernet0/7
interface FastEthernet0/22
interface FastEthernet0/23
duplex full
speed 100
no cdp enable
interface FastEthernet0/24
interface GigabitEthernet0/1
switchport trunk native vlan 102
interface GigabitEthernet0/2
interface VLAN1
no ip address
no ip directed-broadcast
ip nat outside
shutdown
interface VLAN102
ip address 10.11.8.21 255.255.248.0
ip nat outside
ip nat inside source list 199 interface VLAN102 overload
logging facility local6
logging 10.11.9.21
logging 10.24.21.1
access-list 199 dynamic Cluster-NAT permit ip any any
banner motd ^C
Switch 1
^C
line con 0
password 7 xxxxxxxx
transport input none
stopbits 1
line vty 0 4
exec-timeout 35000 0
password 7 xxxxxxxx
login
line vty 5 15
password 7 xxxxxxxx
login
ntp clock-period 11259714
ntp server 10.11.9.21
end
I haven't got a default gateway, any idea how its finding its route?
Thanks again
Dan
It's just broadcast arp-ing for any host it needs to reach. The local router(s) are responding with a Proxy ARP and handling all communications from there upstream.
However, the switch itself doesn't generally communicate to other devices or hosts. the hosts attached to the switch similarly broadcast their ARPs or direct them to their respective default gateway(s) via Layer 2.
Hope this helps, please rate helpful posts.
Dan
Can you clarify when you were testing and were taking different paths, were you connected to the switch console, were you telnetted to the switch, or were you on a workstation connected to a port on the switch.
My guess at this point is that the behavior that you see is related to the fact that the switch is in a cluster and we may be seeing something that is being provided by some other member of the cluster.
Rick
Rick
Thanks everyone for your replies they were very helpful.
My dillema is this. Basically I have one router which is physically the shortest route to my destination ip. Recently we had an MPLS connection installed and that comes with a router. For a certain set of ip blocks the default route is set to the MPLS router. When I traceroute from the switch instead of going through the old router (router 1) it defaults out to the MPLS network router, but I haven't configured the switch to do that.So how is figuring out that the preferred direction is the MPLS network router?
Rick, in response to your question.
I'm telnetting onto the switch from my office workstation to our datacentre through a les line connected into an internal router. which inturn is connected on to the switch to which I am telnetting to.
Any further ideas?
Thanks again
Dan
Dan
So you are telnetting to the address 10.11.8.21 and doing the traceroute from that address? Perhaps it would be helpful if you could give us a bit more information about addresses where the behavior is as you expect and addresses where the behavior is not what you expect.
As I and others have said if this is a layer 2 switch then it is not making any routing decisions itself. I continue to wonder if some other member of the switch cluster is configured as a layer 3 switch and could be making decisions like that.
Rick
Rick
Sorry for the late reply, I've been away.
Thanks for your patience with this.
Ok here is a traceroute from a switch not in the cluster:
switch5#traceroute yyy.yyy.17.7
Tracing the route to 7.0-31.17.yyy.yyy.in-addr.arpa (yyy.yyy.17.7)
1 green.example.com (10.11.8.2) 3 msec 0 msec 3 msec
2 * *
It seems to timeout but thats a separate problem, the route at least is correct, as that is where I would expect the first hop to be. BTW the above is the internal router.
From a switch in the cluster I get:
1 mpls-gw.example.com (10.11.8.18) 1006 msec 0 msec 2 msec
2 10.1.example.com (10.1.54.253) 3 msec 5 msec 13 msec
3 kkk.kkk.5.131 47 msec 50 msec 50 msec
4 kkk.kkk.0.14 63 msec 53 msec 44 msec
I've attached the switch configs for all those switches in the cluster:
BTW: These switches are cisco 3500xl series, so they are fully layer 2 and not layer 3.
If you need any more info please ask.
Thanks again
Dan
Dan
Thanks for posting the additional information. I have looked at it and have a couple things to discuss.
First at the beginning of the file is configuration of BGP and some static routes. Given the way you have obscured addresses in what you post it is difficult to tell whether this impacts the traceroute or not. It is also unclear what device this config comes from. Perhaps you could clarify?
I am puzzled about the layer 2/layer 3 functionality. The switch configs that you have posted do not have a default gateway configured. If they were pure layer 2 switches and did not have a default gateway configured then they would not be able to access any remote address.
I note that the swithes have their management addresses in VLAN 102. Do you know what device(s) connect to VLAN 102 that do have layer 3 functionality? I assume that there is something connected via trunk to these switches.
I also note that switch 1 configures VLAN 102 with ip nat outside while switch 2 and 3 do not. I am not clear why it is this way or what impact it might have. I also wonder how this could be if the switch were a pure layer 2 implementation.
Rick
Rick
Hi Rick
The bgp listing at the top of the config was put in there by mistake, apologies for the confusion. Basically if you scroll down a little you'll see where the real config is meant to start.
To be honest I inherited this infrastructure, and the person who built it has gone. So I'm trying to make sense of whats happening with it.
When you say that the switches do not have a default gateway, is it always necessary, if so shall I add one and if I do will it affect current traffic?
Connected to switch1 is a layer 3 router (cisco 3600 series). It is in VLAN 102. Is this the key to the solution?
Could you please highlight what the problem could be in terms of nat you mentioned.
Also could you recommend improvemts to the design, I am all open to ideas.
Once again I appreciate your help and patience. I've been doing a lot of reading and I hope to grasp this soon.
Thanks again.
Dan
Anymore suggestons about this, I'm baffeled!!
Dan
Hi Dan,
The switch actually has nothing to do with finding the route for a given packet. All it will do when making a forwarding decision is to look at the destination MAC address in the ethernet header.
If it is known, it will send the frame out the port listed in the mac-address table. If it is unknown, it will flood the frame on every port in the VLAN.
This switch has trunks configured, probably to other switches or perhaps to a router. If it is connected to another layer 2 switch, the other switch will behave the same way. Eventually the packet will reach a layer 3 switch or a router, which will then forward the packet based on the destination subnet, which it should have in its routing table.
Does that make more sense now?
HTH,
Bobby
*Pleae rate helpful posts
ankurbhasin
Level 9
Level 9
Hi Dan,
If it is a pure layer 2 switch it is not that much smart. If you just issue a trace command it will check its default gateway which you I am sure have configured and will reach its gateway and your gateway is I am sure a router which is intelligent enough to find the best path.
HTH, if yes please rate the post.
Ankur
Prashanth Krishnappa
What switch is it? If it is a Layer 2 switch only, you would have configured a default gateway on the switch. If it is a L3 switch, check to see if it has some routing protocol configured. Also, check to see if the router is Proxy ARPing.
