How to clear the counters for Public buffer pools?
slytell
Is there a command to clear the counters for the Public buffer pools? I thought 'clear logging' would have done it but it did not.
Thanks in advance,
Steve
donewald
Level 6
Level 6
Steve,
No, buffer counters are reflecitive of router uptime so reload is the only way to clear these.
Hope this helps you,
Don
donewald
Level 6
Level 6
Steve,
Don
Thanks for the quick response and the information!
Steve
