How to configure Port forwarding in Cisco catalyst 2950 switch
thiyaguarc
Hi guys!
Could you please send me any link about how to configure port forwarding in Cisco catalyst 2950 switch or cisco 2600 Router.
Thanks in advance!
Prashanth Krishnappa
What do you mean when you say "port forwarding"? Can you elaborate?
thiyaguarc
In our office we are using PCAnywhere. Pcanywhere will work only with the static IPs. Consider that I am configuring my Cisco 2950 Switch as DHCP. And the default port used by pcanywhere is 5631(tcp) and 5632(udp). I will configure anyother free ports(5633 & 5634...) for other machines for pcanywhere.
I can configure the switch to forward the request which comes to the port 5631 and 5632 to a particular machine. and like that 5633 and 5634 to forward to another machine.
Hope you can understand. This option is available in Linksys wireless-G Broadband routers.
Like that can we configure it in the Cisco 2950 switch or Cisco 2600 router.
Thanks in advance!
thiyaguarc
Thanks in advance!
