08-25-2003 11:35 PM - edited 03-02-2019 09:52 AM
I have a situation to connect a overlay network with 3550,to the existing 2meg links via 3640,and to core switch 4506.
I was hoping to connect the 2 gig ports to the 4506 and make them a trunk ports,and allowing the Vlan`s within that building. present all the users go via 4506(l3),what will be performance issue of connecting the 3550 as a trunk port and allowing the Vlans of that building ?
or is there any better way of connecting 2 core switches ? core switches will be 4506 ,but for the building Lan USERS will be 3550 as a core switch ?
any help please.
Sam
09-01-2003 01:31 PM
You could use isl/802.1q trunking over the ports on the core switches. Here's a document that describes the procedure.
09-02-2003 11:36 AM
Mnay thanks for your URL ,how do I find out how much bandwidth is used here ,I have etherchanneld 2 gig ports between 4506 and 3550..
when I do sh eth chann,do I expect it be 4gig ?
regards
Sam
