Introduction to Packet Tracer, Create a Simple Network
YatinVij
I have went through this exercise/lab various times, and I keep having the same problem, in which when I ping Cisco.com, I get a message saying "Ping request could not find host Cisco.. Please check the name and try again". I would appreciate if anyone could help.
Hi @YatinVij
Currently, the server is connected to the Eth6 interface of the cloud:
But your cloud connection points to the Fa9 interface:
To correct this you can change the cloud connection to the Fa9 interface:
After that change, connectivity is successful:
Remember to mark the correct answers or solve them, because that helps other users with similar doubts.
13 Replies 13
omz
packet tracer is a simulation environment .. you don't have internet connectivity from the devices
https://www.packettracernetwork.com/features/real-network-connection.html
luis_cordova
Hi @YatinVij
Compress your exercise (winzip) and attach it to check.
This is the network I built in the packet tracer
Hi @YatinVij
Thank  You so much, I have been stuck on this for 2 days.
I tried following the solution you proffered, but i FastEthernet9 wasn't even available to me as an option. So I made use of FastEthernet8, but still didnt get any results.
Assistance please.
Hi @Khadkay
Hi @luis_cordova
winzip attached.
Hi @Khadkay
I have checked your exercise and you must make two changes:
1-Go to the cloud > config > cable and remove the current connection
Replace the Ethernet6 interface with the FastEthernet8 interface and add that new connection
That connection should look like this:
Remember to mark the correct answers as solved, because that helps other users with similar doubts.
Hi @Khadkay
The second change is made on the wifi router
2-Go to the GUI tab of the router and change the IP of the router (for example the IP 192.168.0.1/24), also assigns the server IP as DNS (208.67.220.220)
Save the changes
Now go to both PCs and renew the DHCP request (click static and click DHCP)
After these changes, connectivity is successful.
Hi @luis_cordova
This was extremely helpful! I can finally continue learning without having revist uncompleted work! Thank you.
