IOS CLI. How to filter case insensitive?
mario_kmc
Hello everyone,
Is there a way to filter IOS output (include/exclude/begin...) case insensitive?
Mario Pinho
5 Replies 5
Rolf Fischer
Level 9
Level 9
Hi Mario,
not really.
You can use patterns like [Vv]lan, (VLAN|vlan) or [Vv][Ll][Aa][Nn] but that's not handy at all, is it?
Are you looking for something special?
Best regards
Rolf
Hi Fischer,
Thank you. I have considered these and they come in handy in some command outputs where first letter can be capitalized.
I'm not looking for something in particular but full case insensitive searching for user inserted commands like ACL names, descriptions, route-maps, etc. While we do try to maintin rules (all small caps for example) sometimes they are not respected. With case insensitive search I can just put the word and see results instead of having to think of combinations or having to copy text to notepad++ and do a search there.
SecureCRT also helps with its search feature but that gets out of hand in a long session
Hi Mario,
I see. I don't know any freeware software for such configuration compliance tasks.
If you want to have some kind of automation you could
  1. Download your running-configs to a TFTP server and use grep or a more advanced script to extract the lines your're looking for (the TFTP download could also be done by that scipt =>SNMP)
  2. Use TCL if your devices support it
A simple example:
R1#show int loop0 description
Interface                      Status         Protocol Description
Lo0                            up             up       TEST
R1#tclsh
R1(tcl)#puts [regexp {test} [exec "show int loop0 descr"]]
R1(tcl)#puts [regexp -nocase {test} [exec "show int loop0 descr"]]
R1(tcl)#tclquit
There's a section for EEM scripting, so if you want to create a custom command for your needs, you'll get help there.
Best regards
Rolf
wireman84
MY VOTE
Does not exist, but really should!  Cisco should add to IOS!  Something like "show run | inc -i cellular" for example.
mcardinal
A -i option like grep uses would definitely be preferred, but for the case I was searching this topic for...
show running-config | include [Vv][Ll][Aa][Nn]
works just fine  Thank you Rolf Fischer!
