07-02-2004 05:49 AM - edited 03-02-2019 04:48 PM
Hello everybody,
After updateing IOS
to: c1700-k9o3sv8y7-mz.123-8T.bin
on a Cisco1760-V3PN/K9
i can not save the running config. By console, by telnet ssh, by SDM 1.2
IOS Message:
myxx# copy runn start
Destination filename [startup-config]?
Building configuration...
% Warning: Saving this config to nvram may corrupt any network management or security files stored at the end of nvram.
Continue? [no]:
What to Do ?
I tried with "erase startup..." but it does not help
Now i get massages like:
.Jul 3 10:20:13.771 UTC: %SYS-4-CONFIG_NV_OVERRUN: Non config data present at the end of nvram is corrupted[OK]
thank Robert
07-05-2004 07:44 PM
Sounds like your config file is larger than the NVRAM. I'm not familar with the 1700 series but I had this issue today on a 3620 with 12.2(5).
near the bottom of a 'show version' will display the size of the NVRAM. In my case the "non-volatile configuration memory" is only 29K. As seen in the show flash output my config file 'router-confg' is over 38K. The way around this was to configure compression for the config file. This may or may not be an option for your 1700.
router#config t
service compress-config
exit
router#sh ver
IOS (tm) 3600 Software (C3620-IS-M), Version 12.2(5), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Tue 11-Sep-01 18:13 by pwade
Image text-base: 0x600089A8, data-base: 0x61180000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
router uptime is 2 hours, 55 minutes
System returned to ROM by reload at 20:35:24 est Mon Jul 5 2004
System restarted at 20:36:41 est Mon Jul 5 2004
System image file is "flash:c3620-is-mz.122-5.bin"
cisco 3620 (R4700) processor (revision 0x81) with 44032K/5120K bytes of memory.
Processor board ID 26434670
R4700 CPU at 80Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
2 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
router#sh flash
System flash directory:
File Length Name/status
1 10835776 c3620-is-mz.122-5.bin
2 38741 router-confg
[10874648 bytes used, 5378280 available, 16252928 total]
07-05-2004 11:09 PM
Thank's!
After searching in Knowlidge Base i found the compress option.
Anyway it was interresting that my config was 13 k and NVRAM was 32 k and shows me 8 k free at the time of message.
"this is now the picture with compression with a 14 k config"
xxxx#sh file system
File Systems:
Size(b) Free(b) Type Flags Prefixes
- - opaque rw archive:
- - opaque rw system:
29688 15614 nvram rw nvram:
xxxx#copy runn start
Compressed configuration from 14140 bytes to 6422 bytes[OK]
xxxx#sh vers
Cisco IOS Software, C1700 Software (C1700-K9O3SV8Y7-M), Version 12.3(8)T, RELEASE SOFTWARE (fc2)
Cisco 1760 (MPC860P) processor (revision 0x500) with 116332K/14740K bytes of memory.
Processor board ID FOC081727CC (2784819715), with hardware revision 0000
MPC860P processor: part number 5, mask 2
1 Ethernet interface
1 FastEthernet interface
2 ISDN Basic Rate interfaces
1 Virtual Private Network (VPN) Module
2 Voice FXS interfaces
4 Voice NT or TE BRI interfaces
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
