IPV6 NAT-PT problem
Hi, I am installing a NAT-PT router translator to join ipv4 and ipv6 networks. I keep getting this error message:
*Feb 21 14:00:36.959: IPv6 NAT:v4tov6 entry not found
Here is the running config of the NAT-PT, I`ve used all my cards and I can`t figure out what the problem is. HElp please !
#show run
Building configuration...
Current configuration : 2468 bytes
version 12.4
hostname TRANSLATOR
boot-start-marker
boot system flash:c2800nm-advipservicesk9-mz.124-4.T1.bin
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip domain lookup
ip domain name yourdomain.com
ipv6 host s3 3FFE:C00:C18:F004:213:80FF:FE4F:A4C1
voice-card 0
no dspfarm
username xxx privilege 15 secret xxxx
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$
ip address 10.10.10.1 255.255.255.248
duplex full
speed 100
ipv6 address 3FFE:C00:C18:F004::1/64
ipv6 enable
ipv6 nat prefix 3FFE:C00:C18::/96 v4-mapped v4map_acl
ipv6 nat
interface FastEthernet0/1
duplex auto
speed auto
ipv6 enable
ipv6 nat
ip classless
ip http server
ip http authentication local
no ip http secure-server
access-list 1 permit 192.168.0.0 0.0.255.255
ipv6 nat translation udp-timeout 600
ipv6 nat v4v6 source list 1 pool v6pool
ipv6 nat v4v6 pool v6pool 3FFE:C00:C18:F::1 3FFE:C00:C18:F::9 prefix-length 128
ipv6 nat v6v4 source list pt-list pool v4pool overload
ipv6 nat v6v4 source list pt-list1 pool v4pool
ipv6 nat v6v4 pool v4pool 192.168.2.1 192.168.2.10 prefix-length 24
ipv6 access-list pt-list1
permit ipv6 3FFE:C00:C18::/48 any
control-plane
banner login ^C
Cisco Router and Security Device Manager (SDM) is installed on this device. This
feature requires the one time use, initial credentials, of username "cisco"
with password "cisco".
Please change these publicly known initial credentials through SDM or IOS CLI.
Here's the Cisco IOS command:
no username cisco
NOTE: Please add a new username to be able to launch SDM for router management.
For more information about SDM please follow the instructions in the QUICK
START GUIDE for your router or at
http://www.cisco.com/go/sdm
^C
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
pradeepde
Level 5
Level 5
check out the following link on Implementing NAT-PT for IPv6 :
http://www.cisco.com/en/US/products/ps6441/products_configuration_guide_chapter09186a00801d6600.html
hope this helps.
Thank you for your help. I have used this link for configuring this feature and It didn´t work OK.
Do you have another link with diagram or topologies?.
Regards.
