Is flash and dram interchangeable from 2501 to an accespro card
kmcguinn
I'm starting to build a lab and I've got an accespro card that I'd like to
upgrade the flash and dram. I've got a broken 2501 and I'd like to use the
flash and dram out of it and put it in the accesspro card. Does anyone know
if the flash and dram are compatable?
Prashanth Krishnappa
DRAM should be compatible. The part numbers for both 2501 and Accesspro DRAM are the same
MEM-1X4D
MEM-1X8D
MEM-1X16D
Flash does not seem to be compatible
