ā09-06-2004 04:31 AM - edited ā03-02-2019 06:16 PM
hello !
i have a problem. I have various remotes routers calling in AS5300 using the same username and password. They do well the call but they don't ping and i don't have theirs controls. In spite of it the AS5300 learnt theirs routing routes. When I do "show users" donĀ“t fill in the peer address field.
The remote router configurations are:
nterface Dialer1
ip unnumbered Loopback0
encapsulation ppp
dialer pool 1
dialer string 00900841111
dialer string 09008441111
dialer string 900844111
dialer load-threshold 128 outbound
dialer watch-group 1
dialer-group 1
no fair-queue
no cdp enable
ppp authentication chap callin
ppp chap hostname cisco
ppp chap password 1234
ppp multilink
ppp multilink links maximum 2
ppp multilink endpoint
the configuration Access Server is;
multilink bundle-name endpoint
interface Serial0:15
no ip address
encapsulation ppp
no logging event link-status
dialer rotary-group 1
no snmp trap link-status
isdn switch-type primary-net5
isdn incoming-voice modem
no fair-queue
no cdp enable
ppp multilink
interface Dialer1
encapsulation ppp
no ip split-horizon
no ip mroute-cache
dialer in-band
dialer-group 1
no peer default ip address
no fair-queue
no cdp enable
ppp authentication chap pap
ppp ipcp accept-address
thank .i need yours helps
ā09-06-2004 04:50 AM
I see you have "no peer default ip address". This means the remote IP address will be determined entirely by the remote router.
Could you please check that each remote router has a distict multilink endpoint name (i.e. hostname), and each one has a different IP address on its dialer interface.
You say that you can see routes installed for each remote router, but that they are all coming into the same bundle. That sounds like are not differentiating their endpoint names.
I have always put "ppp multilink" on the dialer interface as well, but I don't know whether that is common praactice.
Does this help?
Kevin Dorrell
Luxembourg
ā09-06-2004 07:14 AM
Can you please try these commands:
interface Dialer1
dialer mult-map-same-name <== hidden command
ppp ipcp ignore-map
ppp multilink
There is another way of doing the same by using Virtual-Profiles.
Thanks, Mak
ā09-06-2004 10:52 PM
hello!. I have attempted with the commands that you give me.....Congratulations!....you're good.
it is in this way. Thank you for your atention.
