06-05-2004 05:27 AM - edited 03-02-2019 04:11 PM
I want to know that for what purpose we use dialer rotary-group command in interface mode. What is the differnce between dialer pool-member and dialer rotary-group command.
06-05-2004 06:35 AM
the rotary-group command is used to associate multiple physical interfaces with one specific dialer interface. All physical interfaces in the same rotary group have the same characterisics as the associated dialer interface. Let´s say you have BRI0 and BRI1 and you want those two interfaces to be associated with dialer interface 1. So in interface configuration mode you would configure:
Router(config)#interface bri0
Router(config-if)#dialer rotary-group 1
Router(config)#interface bri1
The rotary group number corresponds with the dialer interface, 1 in this case.
The dialer pool-member command associates physical interfaces with dialer interfaces as well, but the physical interfaces can be associated with more than one dialer interface, hence allowing the physical interface to be used with multiple configurations.
Let´s say you have two BRI interfaces and four dialer interfaces (whereby all of the dialer interfaces have different configurations), you configure the following, which allows all dialer interfaces to use both physical BRI interfaces:
interface BRI0
dialer pool-member 1
dialer pool-member 2
dialer pool-member 3
dialer pool-member 4
interface BRI1
interface Dialer 1
dialer pool 1
interface Dialer 2
dialer pool 2
interface Dialer 3
dialer pool 3
interface Dialer 4
dialer pool 4
HTH,
Georg
06-05-2004 09:12 AM
Follow up on what Georg has well said above, for some Pros n Cons on using legacy ddr (dialer rotary group) vs using dialer profiles & which is preferred method when, please refer:
http://cisco.com/en/US/tech/tk801/tk133/technologies_tech_note09186a0080094e6c.shtml
Thanks, Mak.
