ISDN Keep triggering
maher
Hi there,
Lately, I found that my ISDN router is keep on triggering and dailing to my HQ eventhough the primary link is up. When doing the traceroute and sh ip route <prefix> it is still preferring primary.
Herewith I found that something intersting under sh dialer:
BRI1/7:1 - dialer type = ISDN
Idle timer (120 secs), Fast idle timer (20 secs)
Wait for carrier (30 secs), Re-enable (160 secs)
Dialer state is multilink member
Dial reason: Multilink bundle overloaded
Interface bound to profile Di1
Current call connected 00:00:00
Connected to 12345678 (HQ)
Anyone know the reason of Multilink bundle overloaded?
thanks in advance.
maher
14 Replies 14
Richard Burts
Maher
Without knowing more about your environment it is hard to know the answer to your situation. It would be helpful if you would post the configuration of the dialer interface (I assume from the output that you have configured dialer profiles), of the BRI interface, and of the primary interface.
It would also be helpful to have the output of debug dialer.
I will make a guess without having seen the information that I asked for: do you have backup interface configured on the primary and do you specify backup load? If so it could bring up the ISDN based on the load level of the primary link.
Rick
Rick
Hi Rbuts,
Thanks for the fast respond. Below is my configuration for the ISDN.
interface BRI1/0
no ip address
encapsulation ppp
dialer pool-member 1
isdn switch-type basic-net3
no cdp enable
ppp authentication chap
ppp multilink
interface BRI1/1
no ip address
encapsulation ppp
no cdp enable
ppp multilink
interface BRI1/2
no ip address
encapsulation ppp
no cdp enable
ppp multilink
interface BRI1/3
no ip address
encapsulation ppp
no cdp enable
ppp multilink
interface BRI1/4
no ip address
encapsulation ppp
no cdp enable
ppp multilink
interface BRI1/5
no ip address
encapsulation ppp
no cdp enable
ppp multilink
interface BRI1/6
no ip address
encapsulation ppp
no cdp enable
ppp multilink
interface BRI1/7
no ip address
encapsulation ppp
no cdp enable
ppp multilink
interface Dialer1
description ISDN backup to HQ
ip address 10.0.0.1 255.255.255.252
encapsulation ppp
dialer pool 1
dialer remote-name HQ
dialer rotor best
dialer enable-timeout 160
dialer string 12345678
dialer load-threshold 1 either
dialer max-call 16
dialer-group 1
fair-queue 64 16 0
no cdp enable
ppp chap hostname R1
ppp chap password xxxxxxx
ppp multilink
If you need any info, please let me know.
regards,
maher
Oppsss...forget to post the debug dialer:
Jan 11 15:59:07: Di1 DDR: ip (s=10.0.0.1, d=255.255.255.255), 54 bytes, outgoing interesting (list 199)
Jan 11 15:59:10.421: %ISDN-6-LAYER2UP: Layer 2 for Interface BR1/6, TEI 66 changed to up
Jan 11 15:59:11.330: %LINK-3-UPDOWN: Interface BRI1/6:1, changed state to up
Jan 11 15:59:11.338: %DIALER-6-BIND: Interface BR1/6:1 bound to profile Di1
access-list 199:
access-list 199 deny udp any any eq snmp
access-list 199 deny udp any any eq ntp
access-list 199 deny ospf any any
access-list 199 permit ip any any
thanks again.
maher
Looks like a broadcast is triggering your dialer. Do you also have RIP or anything similar on this router?
Daniel
Hi Daniel,
My primary link is running OSPF. According to the access-list 199, the packets does not hit the ospf statements.
regards,
maher
It looks like RIP v1 or something like that.
If you change the last line of your access list to access-list 199 permit any any log, then you will get some information about the packets that are triggering the ISDN. Unfortunately, it will stop the backup solution working at all, because of an issue with the log keyword on a dialer-list access-list. However, it will tell you about the packets, and you can remove the log immediately afterwards.
You could try slipping this line into the access list: access-list 199 deny ip any host 255.255.255.255. That will stop any broadcasts from triggering the ISDN. But it would be nice to know what it is you are blocking.
Kevin Dorrell
Luxemborg
Hi Kevin,
Thanks for the suggestion.FYI, I did run command ip helper address at my LAN. Would it be the issues?
regards,
maher
It could be the ip helper-address, but the packets triggering the ISDN were send to the IP broadcast address, so did you do ip helper-address 255.255.255.255?
Kevin Dorrell
Luxembourg
Hi Kevin,
Nope. I use ip helper-address 203.x.x.x address. Hmm..not sure sure this could be the reason.
regards,
maher
No, nor do I.
I think you'll have to put that "log" keyword at the end of the last line of your ACL, and look at the messages. Just for enough time to capture one of the packets. Then remove it again. The log message will tell you the source and destination addresses, and also the source and destination ports (because you specify ntp/snmp port numbers elsewhere in your ACL.)
Kevin Dorrell
Luxembourg
Hi Kevin,
Since this is becoming more and more intersting things, I figure out to picture into diagram, easy for us to troubleshoot and diagnose..
regards,
maher
Hi Kevin,
regards,
maher
It is an interesting diagram that you have posted. It has a lot of information that does not seem to relate to the problem being discussed in this forum. And it is not consistent with previous parts of this discussion. In particular your earlier post had address 10.0.0.1 as the address on the dialer interface of the router doing the dialing. The diagram has that address as the loopback of router CE-A1.
So I think we need some clarification.
It might be helpful if you posted the ourput of show ip protocol on the router which is doing the dialing. I suspect that what we will really need is the complete config of the router so that we can try to find what is causing the dialing to happen.
Rick
Rick
Hi Rick and others,
I'm deeply sorry that my last posting makes everyone in the thread confused and feel anonying. The pdf files attach is the actual diagram.
Anyway, the problem is solve after changing and advertise the loopback address in router CE-D2 into area 1.
It seems to be like discontigous area. But what makes me confused a little bit is that, in router CE-B2 and CE-C2 loopback addresses are advertising in area 0 still reachable? Done few test my removing the loopback address under router ospf and still reachable...it seems to be that the advertising the loopback address is useless in this network topology.....
thanks in advance.
maher
