ISDN monitoring & reporting.
Can anybody out there recomend some software?
I have a Cisco 3725 router at the hub of a star WAN topology. The remote routers are all connected via ISDN.
The WAN is not complex at all.
All I want is some software that can collect data that will enable me to create reports that can tell me, at a glance, which branches are using the WAN the most, at what times they dialing up and maybe what the purpose of the call(E-mail, credit card auth etc).
I've been told that the Cisco Secure ACS package will do the trick, but I think that it does too much, plus it gets involved with the authenticating of the remote sites, which I don't want it doing.
I've heard good things about the SolarWinds offering, but again, I'm turning to you guys, cos you are in the know!
Any ideas?
George
sbanyas
Are your devices sending syslog messages anywhere? If so, some simple scripting based on syslog entries would probably do the trick for you and be relatively inexpensive.
