Bookmark
Subscribe
9968
ISR4431/K9 %IOSXE_QFP-2-LOAD_EXCEED: Slot: 0, QFP:0, Load 90% exceeds
cristian.munoz
Level 4
Level 4
Hi All
I have cisco ISR4431/K9 router logs below. what is cause root for the following notifications?
024719: Nov 7 09:42:23: %IOSXE_QFP-2-LOAD_RECOVER: Slot: 0, QFP:0, Load 29% recovered.
024720: Nov 7 09:42:38: %IOSXE_QFP-2-LOAD_EXCEED: Slot: 0, QFP:0, Load 90% exceeds the setting threshold.
024721: Nov 7 09:45:38: %IOSXE_QFP-2-LOAD_RECOVER: Slot: 0, QFP:0, Load 17% recovered.
024722: Nov 7 09:46:13: %IOSXE_QFP-2-LOAD_EXCEED: Slot: 0, QFP:0, Load 100% exceeds the setting threshold.
024723: Nov 7 09:46:33: %IOSXE_QFP-2-LOAD_RECOVER: Slot: 0, QFP:0, Load 46% recovered.
TIA
Cristian
10 Replies 10
balaji.bandi
what is the version of the code (show version)? is that affected in your network performance now ? how is your CPU process.
check also BUG
if the bug not affecting, worth checking SFP and Cables, spanning tree, routing
BB
Hi BB
Cisco IOS XE Software, Version 16.09.02
Cisco IOS Software [Fuji], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.9.2, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
System image file is "bootflash:isr4400-universalk9.16.09.02.SPA.bin"
CPU utilization for five seconds: 1%/0%; one minute: 2%; five minutes: 2%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
1 92 4407 20 0.00% 0.00% 0.00% 0 Chunk Manager
2 4376478 11234910 389 0.00% 0.00% 0.00% 0 Load Meter
3 374 232 1612 0.00% 0.01% 0.03% 866 SSH Process
4 0 1 0 0.00% 0.00% 0.00% 0 Retransmission o
5 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Dispatc
6 22 12 1833 0.00% 0.00% 0.00% 0 RF Slave Main Th
7 0 1 0 0.00% 0.00% 0.00% 0 EDDRI_MAIN
8 0 1 0 0.00% 0.00% 0.00% 0 RO Notify Timers
9 55089670 9491243 5804 0.00% 0.10% 0.06% 0 Check heaps
10 120150 936266 128 0.00% 0.00% 0.00% 0 Pool Manager
11 0 1 0 0.00% 0.00% 0.00% 0 DiscardQ Backgro
12 0 2 0 0.00% 0.00% 0.00% 0 Timers
13 503 48802 10 0.00% 0.00% 0.00% 0 WATCH_AFS
14 36048 244325 147 0.00% 0.00% 0.00% 0 ARP Input
15 1305988 58557724 22 0.00% 0.00% 0.00% 0 ARP Background
16 0 2 0 0.00% 0.00% 0.00% 0 ATM Idle Timer
17 0 1 0 0.00% 0.00% 0.00% 0 ATM ASYNC PROC
18 0 1 0 0.00% 0.00% 0.00% 0 CEF MIB API
19 0 2 0 0.00% 0.00% 0.00% 0 DDR Timers
20 156 12 13000 0.00% 0.00% 0.00% 0 Entity MIB API
21 454 139 3266 0.00% 0.00% 0.00% 0 PrstVbl
22 0 2 0 0.00% 0.00% 0.00% 0 Serial Backgroun
23 0 1 0 0.00% 0.00% 0.00% 0 RMI RM Notify Wa
24 0 2 0 0.00% 0.00% 0.00% 0 ATM AutoVC Perio
25 0 2 0 0.00% 0.00% 0.00% 0 ATM VC Auto Crea
26 614723 28078203 21 0.00% 0.00% 0.00% 0 IOSXE heartbeat
27 2 72 27 0.00% 0.00% 0.00% 0 DB Lock Manager
28 0 1 0 0.00% 0.00% 0.00% 0 DB Notification
29 0 1 0 0.00% 0.00% 0.00% 0 IPC Apps Task
30 0 1 0 0.00% 0.00% 0.00% 0 ifIndex Receive
31 106784 11231541 9 0.00% 0.00% 0.00% 0 IPC Event Notifi
32 954405 54848845 17 0.00% 0.00% 0.00% 0 IPC Mcast Pendin
33 0 1 0 0.00% 0.00% 0.00% 0 Platform appsess
34 8975 936175 9 0.00% 0.00% 0.00% 0 IPC Dynamic Cach
35 115621 11231541 10 0.00% 0.00% 0.00% 0 IPC Service NonC
36 0 1 0 0.00% 0.00% 0.00% 0 IPC Zone Manager
37 989893 54848845 18 0.00% 0.00% 0.00% 0 IPC Periodic Tim
38 834043 54848846 15 0.00% 0.00% 0.00% 0 IPC Deferred Por
39 0 1 0 0.00% 0.00% 0.00% 0 IPC Process leve
40 0 1 0 0.00% 0.00% 0.00% 0 IPC Seat Manager
41 46708 3209951 14 0.00% 0.00% 0.00% 0 IPC Check Queue
42 0 1 0 0.00% 0.00% 0.00% 0 IPC Seat RX Cont
43 0 1 0 0.00% 0.00% 0.00% 0 IPC Seat TX Cont
44 333011 5617460 59 0.00% 0.00% 0.00% 0 IPC Keep Alive M
45 936654 11232236 83 0.00% 0.00% 0.00% 0 IPC Loadometer
46 0 1 0 0.00% 0.00% 0.00% 0 IPC Session Deta
47 0 1 0 0.00% 0.00% 0.00% 0 SENSOR-MGR event
48 76667 5617459 13 0.00% 0.00% 0.00% 0 Compute SRP rate
49 0 1 0 0.00% 0.00% 0.00% 0 MEMLEAK PROCESS
50 13 392 33 0.00% 0.00% 0.00% 0 AAA_SERVER_DEADT
51 0 1 0 0.00% 0.00% 0.00% 0 Policy Manager
52 0 1 0 0.00% 0.00% 0.00% 0 License IPC stat
53 0 1 0 0.00% 0.00% 0.00% 0 License IPC serv
54 1978 89530 22 0.00% 0.00% 0.00% 0 Net Input
55 0 2 0 0.00% 0.00% 0.00% 0 Dialer event
56 0 1 0 0.00% 0.00% 0.00% 0 SERIAL A'detect
57 0 1 0 0.00% 0.00% 0.00% 0 IOSXE signals IO
58 987917 56174544 17 0.00% 0.00% 0.00% 0 GraphIt
59 0 1 0 0.00% 0.00% 0.00% 0 client_entity_se
60 0 1 0 0.00% 0.00% 0.00% 0 RF SCTPthread
61 0 1 0 0.00% 0.00% 0.00% 0 CHKPT RG SCTPthr
62 0 2 0 0.00% 0.00% 0.00% 0 XML Proxy Client
63 228 2439 93 0.00% 0.00% 0.00% 0 crypto sw pk pro
64 0 2 0 0.00% 0.00% 0.00% 0 License Client N
65 0 1 0 0.00% 0.00% 0.00% 0 Image License br
66 10 21 476 0.00% 0.00% 0.00% 0 SAStorage
67 1 4 250 0.00% 0.00% 0.00% 0 SASConnect
68 729796 29238123 24 0.00% 0.00% 0.00% 0 SASRcvWQ
69 1 5 200 0.00% 0.00% 0.00% 0 SACConnect
70 454909 29239000 15 0.00% 0.00% 0.00% 0 SACRcvWQ
71 54541499 2805969 19437 0.00% 0.10% 0.06% 0 Licensing Auto U
72 0 1 0 0.00% 0.00% 0.00% 0 License HA Consi
73 0 1 0 0.00% 0.00% 0.00% 0 Token Daemon
74 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd
75 1044649 12308241 84 0.00% 0.00% 0.00% 0 Net Background
76 1 3 333 0.00% 0.00% 0.00% 0 IDB Work
77 17117 559579 30 0.00% 0.00% 0.00% 0 Logger
78 1380032 56156766 24 0.00% 0.00% 0.00% 0 TTY Background
79 72 31 2322 0.00% 0.00% 0.00% 0 CTS CORE
80 12414 204262 60 0.00% 0.00% 0.00% 0 SASRcvWQWrk1
81 46 618 74 0.00% 0.00% 0.00% 0 SXP CORE
82 1 16 62 0.00% 0.00% 0.00% 0 IF-MGR control p
83 0 59 0 0.00% 0.00% 0.00% 0 IF-MGR event pro
84 95443411 209919537 454 0.39% 0.24% 0.23% 0 IOSD ipc task
85 6495446 256654107 25 0.00% 0.00% 0.00% 0 IOSD chasfs task
86 45 55 818 0.00% 0.00% 0.00% 0 Crimson flush tr
87 160497 8024775 20 0.00% 0.00% 0.00% 0 REDUNDANCY FSM
88 0 1 0 0.00% 0.00% 0.00% 0 Punt FP Stats Du
89 4323084 28076984 153 0.00% 0.00% 0.00% 0 PuntInject Keepa
90 0 2 0 0.00% 0.00% 0.00% 0 CTS HA
91 0 2 0 0.00% 0.00% 0.00% 0 CTS HA IPC flow
92 0 1 0 0.00% 0.00% 0.00% 0 CTS HA operation
93 3811045 56153663 67 0.00% 0.00% 0.00% 0 Environmental Mo
94 805224 56153642 14 0.00% 0.00% 0.00% 0 RP HA Periodic
95 0 2 0 0.00% 0.00% 0.00% 0 cpf_msg_holdq_pr
96 0 1 0 0.00% 0.00% 0.00% 0 cpf_msg_rcvq_pro
97 0 1 0 0.00% 0.00% 0.00% 0 cpf_process_tpQ
98 0 1 0 0.00% 0.00% 0.00% 0 CEF RRP RF waite
99 0 1 0 0.00% 0.00% 0.00% 0 CONSOLE helper p
100 0 1 0 0.00% 0.00% 0.00% 0 XDR RRP RF waite
101 1196479 56153895 21 0.00% 0.00% 0.00% 0 REDUNDANCY peer
102 10521478 561744830 18 0.00% 0.01% 0.00% 0 100ms check
103 0 1 0 0.00% 0.00% 0.00% 0 CWAN APS HA Proc
104 10559 936244 11 0.00% 0.00% 0.00% 0 RF CWAN HA Proce
105 0 1 0 0.00% 0.00% 0.00% 0 CWAN IF EVENT HA
106 0 4 0 0.00% 0.00% 0.00% 0 ANCP HA
107 0 2 0 0.00% 0.00% 0.00% 0 ANCP HA IPC flow
108 0 1 0 0.00% 0.00% 0.00% 0 QoS HA ID RETAIN
109 0 1 0 0.00% 0.00% 0.00% 0 CHKPT Test clien
110 0 1 0 0.00% 0.00% 0.00% 0 CHKPT Test clien
111 0 1 0 0.00% 0.00% 0.00% 0 CHKPT Test clien
112 0 1 0 0.00% 0.00% 0.00% 0 CHKPT Test clien
113 0 1 0 0.00% 0.00% 0.00% 0 CHKPT Test clien
114 0 1 0 0.00% 0.00% 0.00% 0 CHKPT Test clien
115 0 1 0 0.00% 0.00% 0.00% 0 CHKPT Test clien
116 0 1 0 0.00% 0.00% 0.00% 0 CHKPT Test clien
117 0 1 0 0.00% 0.00% 0.00% 0 CHKPT Test clien
118 0 1 0 0.00% 0.00% 0.00% 0 CHKPT Test clien
119 0 1 0 0.00% 0.00% 0.00% 0 CHKPT Test clien
120 0 3 0 0.00% 0.00% 0.00% 0 ARP HA
121 54223899 327108840 165 0.07% 0.12% 0.11% 0 IOSXE-RP Punt Se
122 0 1 0 0.00% 0.00% 0.00% 0 IOSXE-RP Punt IP
123 0 1 0 0.00% 0.00% 0.00% 0 ACL Log Punt Ser
124 0 1 0 0.00% 0.00% 0.00% 0 ACL deny punt se
125 0 1 0 0.00% 0.00% 0.00% 0 OFSDN Punject Pr
126 0 1 0 0.00% 0.00% 0.00% 0 IOSXE-RP SPA TSM
127 0 1 0 0.00% 0.00% 0.00% 0 IOSXE-RP QFP HA
128 0 1 0 0.00% 0.00% 0.00% 0 Network-rf Notif
129 32 63 507 0.00% 0.00% 0.00% 0 DBAL EVENTS
130 0 1 0 0.00% 0.00% 0.00% 0 DHCPC HA
131 0 1 0 0.00% 0.00% 0.00% 0 DHCPD HA
132 0 1 0 0.00% 0.00% 0.00% 0 DHCPv6 Relay HA
133 0 1 0 0.00% 0.00% 0.00% 0 DHCPv6 Server HA
134 0 2 0 0.00% 0.00% 0.00% 0 SISF HA Process
135 0 1 0 0.00% 0.00% 0.00% 0 Crypto PKI-HA
136 0 1 0 0.00% 0.00% 0.00% 0 IKE HA Mgr
137 0 1 0 0.00% 0.00% 0.00% 0 IPSEC HA Mgr
138 6 12 500 0.00% 0.00% 0.00% 0 RF Master Main T
139 0 7 0 0.00% 0.00% 0.00% 0 RF Master Status
140 1 6 166 0.00% 0.00% 0.00% 0 SACRcvWQWrk1
141 16196 1162161 13 0.00% 0.00% 0.00% 0 SACRcvWQWrk2
142 0 1 0 0.00% 0.00% 0.00% 0 BACK CHECK
143 0 2 0 0.00% 0.00% 0.00% 0 Policy bind Proc
144 473812 5617459 84 0.00% 0.00% 0.00% 0 Compute load avg
145 25398174 1872488 13563 0.00% 0.04% 0.00% 0 Per-minute Jobs
146 5252638 56174589 93 0.00% 0.00% 0.00% 0 Per-Second Jobs
147 108 4063 26 0.00% 0.00% 0.00% 0 Transport Port A
148 32 73 438 0.00% 0.00% 0.00% 0 ACT2 Crypto Engi
149 0 1 0 0.00% 0.00% 0.00% 0 AggMgr Process
150 1 4 250 0.00% 0.00% 0.00% 0 EEM ED MAT
151 36482 1460271 24 0.00% 0.00% 0.00% 0 EEM ED ND
152 0 1 0 0.00% 0.00% 0.00% 0 MACSEC POST rest
153 0 1 0 0.00% 0.00% 0.00% 0 MACSEC POST hand
154 0 1 0 0.00% 0.00% 0.00% 0 MACSEC POST hand
155 0 1 0 0.00% 0.00% 0.00% 0 IOSXE-RP FastPat
156 1396 93627 14 0.00% 0.00% 0.00% 0 NGIO_BRI_POLL_DE
157 0 1 0 0.00% 0.00% 0.00% 0 ASYNC Input
158 0 1 0 0.00% 0.00% 0.00% 0 ASR1000-RP SPA A
159 0 2 0 0.00% 0.00% 0.00% 0 dialer isdn sess
160 0 1 0 0.00% 0.00% 0.00% 0 DSX3MIB ll handl
161 889409 54848846 16 0.00% 0.00% 0.00% 0 fanrp_l2fib
162 0 1 0 0.00% 0.00% 0.00% 0 POS APS Event Pr
163 2 3 666 0.00% 0.00% 0.00% 0 netclk_process
164 0 1 0 0.00% 0.00% 0.00% 0 netclk_ha_proces
165 0 2 0 0.00% 0.00% 0.00% 0 Netsync ESMC pro
166 0 2 0 0.00% 0.00% 0.00% 0 FPD Management P
167 0 1 0 0.00% 0.00% 0.00% 0 FPD Action Proce
168 0 2 0 0.00% 0.00% 0.00% 0 FEC_Link_event_h
169 7553258 438294220 17 0.00% 0.00% 0.00% 0 MCP RP autovc pr
170 0 1 0 0.00% 0.00% 0.00% 0 Src Fltr backgro
171 0 1 0 0.00% 0.00% 0.00% 0 BFD HW EVENT
172 0 1 0 0.00% 0.00% 0.00% 0 BFD IPV6 ADDR CH
173 0 1 0 0.00% 0.00% 0.00% 0 Inline Power
174 0 1 0 0.00% 0.00% 0.00% 0 ESG PM Main proc
175 0 4 0 0.00% 0.00% 0.00% 0 ESG MATM process
176 0 2 0 0.00% 0.00% 0.00% 0 BMA Background
177 0 2 0 0.00% 0.00% 0.00% 0 VMI Background
178 0 1 0 0.00% 0.00% 0.00% 0 SSLVPN Register
179 926159 4333624 213 0.00% 0.00% 0.00% 0 IPSec background
180 198 80 2475 0.00% 0.00% 0.00% 0 OVLD SPA Backgro
181 90405 2624028 34 0.00% 0.00% 0.00% 0 EIGRP-SFv4
182 1644351 11224162 146 0.00% 0.00% 0.00% 0 MGMTE stats Proc
183 0 1 0 0.00% 0.00% 0.00% 0 Inter Chassis Pr
184 649893 56153641 11 0.00% 0.00% 0.00% 0 CWAN CHOCX PROCE
185 0 1 0 0.00% 0.00% 0.00% 0 CE3 Mailbox
186 0 1 0 0.00% 0.00% 0.00% 0 CT3 Mailbox
187 0 1 0 0.00% 0.00% 0.00% 0 HAL Mailbox
188 0 2 0 0.00% 0.00% 0.00% 0 MIP Mailbox
189 920 509 1807 0.00% 0.00% 0.00% 0 CWAN OIR Handler
190 0 1 0 0.00% 0.00% 0.00% 0 TP CUTOVER EVENT
191 0 1 0 0.00% 0.00% 0.00% 0 ASR1K ESMC Proce
192 347368 18718628 18 0.00% 0.00% 0.00% 0 ACE event
193 177161 3795917 46 0.00% 0.00% 0.00% 0 ACE HAPI
194 7015 468113 14 0.00% 0.00% 0.00% 0 ACE policy loade
195 0 1 0 0.00% 0.00% 0.00% 0 RTTYS Process
196 0 2 0 0.00% 0.00% 0.00% 0 CEF switching ba
197 0 1 0 0.00% 0.00% 0.00% 0 ADJ NSF process
198 1743669 56153642 31 0.00% 0.00% 0.00% 0 FHRP Main thread
199 2366863 59748750 39 0.00% 0.00% 0.00% 0 TRACK Main threa
200 1 43 23 0.00% 0.00% 0.00% 0 TRACK Client thr
201 0 1 0 0.00% 0.00% 0.00% 0 VRRP Main thread
202 25249712 877585456 28 0.00% 0.04% 0.05% 0 VRRS Main thread
203 0 1 0 0.00% 0.00% 0.00% 0 HQF TARGET DYNAM
204 0 1 0 0.00% 0.00% 0.00% 0 IEDGE ACCT TIMER
205 0 1 0 0.00% 0.00% 0.00% 0 ISG CMD HANDLER
206 0 2 0 0.00% 0.00% 0.00% 0 IP PORTBUNDLE
207 137884 13714492 10 0.00% 0.00% 0.00% 0 IP Static Sessio
208 0 2 0 0.00% 0.00% 0.00% 0 DVLAN Config Pro
209 224320 13714500 16 0.00% 0.00% 0.00% 0 IP Lite session
210 0 2 0 0.00% 0.00% 0.00% 0 IPAM/ODAP Events
211 29445619 1746767230 16 0.15% 0.04% 0.05% 0 IPAM Manager
212 0 2 0 0.00% 0.00% 0.00% 0 IPAM Events
213 244 4514 54 0.00% 0.00% 0.00% 0 IP ARP Adjacency
214 27728511 1746766512 15 0.00% 0.04% 0.05% 0 IP ARP Retry Age
215 14707 955800 15 0.00% 0.00% 0.00% 0 IP Input
216 0 1 0 0.00% 0.00% 0.00% 0 ICMP event handl
217 881107 56153642 15 0.00% 0.00% 0.00% 0 mDNS
218 1344130 54848836 24 0.00% 0.00% 0.00% 0 BGP Scheduler
219 19562 163682 119 0.00% 0.00% 0.00% 0 MOP Protocols
220 0 1 0 0.00% 0.00% 0.00% 0 AAA EPD HANDLER
221 0 1 0 0.00% 0.00% 0.00% 0 PM EPD API
222 0 1 0 0.00% 0.00% 0.00% 0 DM Proc
223 0 2 0 0.00% 0.00% 0.00% 0 PPP SIP
224 0 2 0 0.00% 0.00% 0.00% 0 PPP Bind
225 0 2 0 0.00% 0.00% 0.00% 0 PPP IP Route
226 2 64 31 0.00% 0.00% 0.00% 0 SSM connection m
227 7878 936175 8 0.00% 0.00% 0.00% 0 SSS Manager
228 0 1 0 0.00% 0.00% 0.00% 0 SSS Policy Manag
229 0 1 0 0.00% 0.00% 0.00% 0 SSS Feature Mana
230 4204715 219431931 19 0.00% 0.00% 0.00% 0 SSS Feature Time
231 0 1 0 0.00% 0.00% 0.00% 0 SSS PM SHIM QOS
232 0 1 0 0.00% 0.00% 0.00% 0 LONG TO SHORT NA
233 0 1 0 0.00% 0.00% 0.00% 0 Timer handler fo
234 0 1 0 0.00% 0.00% 0.00% 0 Prepaid response
235 0 1 0 0.00% 0.00% 0.00% 0 Timed Policy act
236 0 1 0 0.00% 0.00% 0.00% 0 AAA response han
237 75974 3746895 20 0.00% 0.00% 0.00% 0 Spanning Tree
238 0 2 0 0.00% 0.00% 0.00% 0 SpanTree Msg
239 7497379 438294083 17 0.00% 0.00% 0.00% 0 Tunnel BGP
240 0 1 0 0.00% 0.00% 0.00% 0 VRRS
241 1 3 333 0.00% 0.00% 0.00% 0 MKA
242 0 1 0 0.00% 0.00% 0.00% 0 PPCP RP Stats Ba
243 1 2 500 0.00% 0.00% 0.00% 0 Ethernet LMI
244 0 2 0 0.00% 0.00% 0.00% 0 Ethernet OAM Pro
245 1 2 500 0.00% 0.00% 0.00% 0 Ethernet CFM
246 354508 1139142 311 0.00% 0.00% 0.00% 0 mcp callhome per
247 0 2 0 0.00% 0.00% 0.00% 0 IGMP Route Msg H
248 0 1 0 0.00% 0.00% 0.00% 0 IGMP Route Rx Pr
249 0 1 0 0.00% 0.00% 0.00% 0 L2FIB Timer Disp
250 0 1 0 0.00% 0.00% 0.00% 0 MLRIB L2 Msg Thr
251 0 1 0 0.00% 0.00% 0.00% 0 TEMPLATE HA
252 0 1 0 0.00% 0.00% 0.00% 0 DVLAN HA
253 0 1 0 0.00% 0.00% 0.00% 0 HDLC HA
254 0 2 0 0.00% 0.00% 0.00% 0 RG AR
255 1 2 500 0.00% 0.00% 0.00% 0 RG Faults Timer
256 0 2 0 0.00% 0.00% 0.00% 0 RG Protocol Time
257 0 2 0 0.00% 0.00% 0.00% 0 RG Transport Tim
258 0 1 0 0.00% 0.00% 0.00% 0 RG VP
259 0 1 0 0.00% 0.00% 0.00% 0 RABAPOL HA
260 0 2 0 0.00% 0.00% 0.00% 0 RABAPOL HA IPC f
261 0 1 0 0.00% 0.00% 0.00% 0 O-UNI Client Msg
262 0 2 0 0.00% 0.00% 0.00% 0 ATM OAM Input
263 0 2 0 0.00% 0.00% 0.00% 0 ATM OAM TIMER
264 0 2 0 0.00% 0.00% 0.00% 0 SSS Mobility mes
265 1 1 1000 0.00% 0.00% 0.00% 0 IMA PROC
266 1510702 54857404 27 0.00% 0.00% 0.00% 0 L2RIB Thread
267 2420 187249 12 0.00% 0.00% 0.00% 0 Appnav auto disc
268 0 1 0 0.00% 0.00% 0.00% 0 Spanning Tree St
269 0 1 0 0.00% 0.00% 0.00% 0 CCM
270 0 2 0 0.00% 0.00% 0.00% 0 CCM IPC flow con
271 0 1 0 0.00% 0.00% 0.00% 0 SVM HA
272 0 1 0 0.00% 0.00% 0.00% 0 NVE main thread
273 659873 56153623 11 0.00% 0.00% 0.00% 0 PI MATM Aging Pr
274 0 2 0 0.00% 0.00% 0.00% 0 DTP Protocol
275 0 1 0 0.00% 0.00% 0.00% 0 802.1x switch
276 12832 936243 13 0.00% 0.00% 0.00% 0 Port-Security
277 3 12 250 0.00% 0.00% 0.00% 0 EPM IAL Process
278 243603 1452511 167 0.00% 0.00% 0.00% 0 CDP Protocol
279 0 1 0 0.00% 0.00% 0.00% 0 WSMA_NOTIFY
280 34424 936176 36 0.00% 0.00% 0.00% 0 Call Home Timer
281 155 6886 22 0.00% 0.00% 0.00% 0 AAA Server
282 367 11151 32 0.00% 0.00% 0.00% 0 AAA ACCT Proc
283 0 1 0 0.00% 0.00% 0.00% 0 ACCT Periodic Pr
284 0 2 0 0.00% 0.00% 0.00% 0 AAA Dictionary R
285 0 2 0 0.00% 0.00% 0.00% 0 KRB5 AAA
286 4641837 51889559 89 0.00% 0.01% 0.00% 0 CENT_COMMUNICATI
287 0 1 0 0.00% 0.00% 0.00% 0 RADIUS Proxy
288 1 1 1000 0.00% 0.00% 0.00% 0 radius radsec cl
289 0 2 0 0.00% 0.00% 0.00% 0 SNMP DBAL WRAPPE
290 0 1 0 0.00% 0.00% 0.00% 0 SNMP DBAL Cache
291 0 1 0 0.00% 0.00% 0.00% 0 SNMP DBAL Cache
292 0 1 0 0.00% 0.00% 0.00% 0 IPv6 ping proces
293 0 1 0 0.00% 0.00% 0.00% 0 st_pw_oam
294 0 1 0 0.00% 0.00% 0.00% 0 AC Switch
295 0 1 0 0.00% 0.00% 0.00% 0 LSP Tunnel FRR
296 0 1 0 0.00% 0.00% 0.00% 0 MPLS Auto-Tunnel
297 0 2 0 0.00% 0.00% 0.00% 0 OCE punted Pkts
298 0 3 0 0.00% 0.00% 0.00% 0 PIM register asy
299 0 2 0 0.00% 0.00% 0.00% 0 RIB LM VALIDATE
300 0 1 0 0.00% 0.00% 0.00% 0 XDR background p
301 15085 936197 16 0.00% 0.00% 0.00% 0 XDR mcast
302 0 1 0 0.00% 0.00% 0.00% 0 XDR RP Ping Back
303 0 1 0 0.00% 0.00% 0.00% 0 XDR receive
304 0 1 0 0.00% 0.00% 0.00% 0 IPC LC Message H
305 0 1 0 0.00% 0.00% 0.00% 0 XDR RP Test Back
306 8623 936175 9 0.00% 0.00% 0.00% 0 FRR Background P
307 142189 4301695 33 0.00% 0.00% 0.00% 0 CEF background p
308 0 1 0 0.00% 0.00% 0.00% 0 fib_fib_bfd_sb e
309 0 1 0 0.00% 0.00% 0.00% 0 IP IRDP
310 0 6 0 0.00% 0.00% 0.00% 0 SNMP Timers
311 0 2 0 0.00% 0.00% 0.00% 0 PPP Compress Inp
312 0 2 0 0.00% 0.00% 0.00% 0 PPP Compress Res
313 0 1 0 0.00% 0.00% 0.00% 0 Tunnel FIB
314 0 1 0 0.00% 0.00% 0.00% 0 LSD HA Proc
315 1 1 1000 0.00% 0.00% 0.00% 0 CEF RP Backgroun
316 0 2 0 0.00% 0.00% 0.00% 0 Routing Topology
317 582660 28059997 20 0.00% 0.00% 0.00% 0 CEF: IPv4 proces
318 184523 1100413 167 0.00% 0.00% 0.00% 0 ADJ background
319 620 1661 373 0.00% 0.00% 0.00% 0 Collection proce
320 0 3 0 0.00% 0.00% 0.00% 0 ADJ resolve proc
321 0 2 0 0.00% 0.00% 0.00% 0 Tunnel
322 0 1 0 0.00% 0.00% 0.00% 0 Socket Timers
323 4679912 72436441 64 0.00% 0.00% 0.00% 0 TCP Timer
324 1087 6659 163 0.00% 0.00% 0.00% 0 TCP Protocols
325 0 1 0 0.00% 0.00% 0.00% 0 COPS
326 0 2 0 0.00% 0.00% 0.00% 0 Dialer Forwarder
327 4425 78728 56 0.00% 0.00% 0.00% 0 Service Routing
328 2726121 27695849 98 0.00% 0.00% 0.00% 0 BGP I/O
329 3173 187249 16 0.00% 0.00% 0.00% 0 HTTP CORE
330 5293435 56153629 94 0.00% 0.00% 0.00% 0 nbar-graph-sende
331 273966 11231593 24 0.00% 0.00% 0.00% 0 nbar-custom-prot
332 24273 936175 25 0.00% 0.00% 0.00% 0 nbar-auto-custom
333 1510297 56153621 26 0.00% 0.00% 0.00% 0 nbar-sdavc-sched
334 21970 936202 23 0.00% 0.00% 0.00% 0 nbar-pp-monitor
335 237880 13714492 17 0.00% 0.00% 0.00% 0 IP SIP Process
336 0 2 0 0.00% 0.00% 0.00% 0 IP Inband Sessio
337 0 1 0 0.00% 0.00% 0.00% 0 IP Traceroute
338 3 256 11 0.00% 0.00% 0.00% 0 DNS Service
339 0 1 0 0.00% 0.00% 0.00% 0 RARP Input
340 796716 1853626 429 0.00% 0.00% 0.00% 0 IP RIB Update
341 15699 936252 16 0.00% 0.00% 0.00% 0 IP Background
342 62 233 266 0.00% 0.00% 0.00% 0 IP Connected Rou
343 5 96 52 0.00% 0.00% 0.00% 0 static
344 0 2 0 0.00% 0.00% 0.00% 0 App Route Proces
345 0 1 0 0.00% 0.00% 0.00% 0 IPv6 RIB Cleanup
346 0 3 0 0.00% 0.00% 0.00% 0 IPv6 RIB Event H
347 0 1 0 0.00% 0.00% 0.00% 0 PAD InCall
348 0 2 0 0.00% 0.00% 0.00% 0 X.25 Background
349 0 1 0 0.00% 0.00% 0.00% 0 X.25 Encaps Mana
350 0 2 0 0.00% 0.00% 0.00% 0 SCTP Main Proces
351 0 1 0 0.00% 0.00% 0.00% 0 VPDN call manage
352 83737070 46234893 1811 0.00% 0.15% 0.14% 0 Flow Exporter Ti
353 0 2 0 0.00% 0.00% 0.00% 0 Flow Exporter Pa
354 0 2 0 0.00% 0.00% 0.00% 0 VTEMPLATE IPC fl
355 0 2 0 0.00% 0.00% 0.00% 0 XDR FOF process
356 0 1 0 0.00% 0.00% 0.00% 0 RETRY_REPOPULATE
357 0 2 0 0.00% 0.00% 0.00% 0 EFP Errd
358 0 2 0 0.00% 0.00% 0.00% 0 Ether EFP Proces
359 0 2 0 0.00% 0.00% 0.00% 0 Ether Infra RP
360 0 2 0 0.00% 0.00% 0.00% 0 CFM HA IPC messa
361 0 1 0 0.00% 0.00% 0.00% 0 Ethernet PM Proc
362 0 2 0 0.00% 0.00% 0.00% 0 Ethernet PM Soft
363 249297 14512434 17 0.00% 0.00% 0.00% 0 Ethernet PM Moni
364 0 1 0 0.00% 0.00% 0.00% 0 Ethernet Datapla
365 0 2 0 0.00% 0.00% 0.00% 0 ELB HA IPC flow
366 1 73 13 0.00% 0.00% 0.00% 0 IGMPSN L2MCM
367 0 1 0 0.00% 0.00% 0.00% 0 IGMPSN MRD
368 0 1 0 0.00% 0.00% 0.00% 0 IGMPSN
369 0 1 0 0.00% 0.00% 0.00% 0 IGMPSN EI L2MCM
370 0 1 0 0.00% 0.00% 0.00% 0 IGMPSN EI Timer
371 0 1 0 0.00% 0.00% 0.00% 0 IGMPSN EI MRD Ti
372 0 1 0 0.00% 0.00% 0.00% 0 TCP HA PROC
373 938463 56153634 16 0.00% 0.00% 0.00% 0 RUDPV1 Main Proc
374 0 2 0 0.00% 0.00% 0.00% 0 SPA XCVR SENSOR
375 0 1 0 0.00% 0.00% 0.00% 0 IGMPQR
376 0 1 0 0.00% 0.00% 0.00% 0 IGMPQR-EI
377 0 2 0 0.00% 0.00% 0.00% 0 L2FIB Event Disp
378 0 1 0 0.00% 0.00% 0.00% 0 ATM HA
379 0 2 0 0.00% 0.00% 0.00% 0 ATM HA IPC flow
380 0 1 0 0.00% 0.00% 0.00% 0 FR HA
381 0 2 0 0.00% 0.00% 0.00% 0 GLBP HA
382 0 2 0 0.00% 0.00% 0.00% 0 HSRP HA
383 0 2 0 0.00% 0.00% 0.00% 0 Netsync IPC flow
384 0 1 0 0.00% 0.00% 0.00% 0 RG If-Mgr Timer
385 0 2 0 0.00% 0.00% 0.00% 0 RG Media Timer
386 0 2 0 0.00% 0.00% 0.00% 0 VRRP HA
387 0 1 0 0.00% 0.00% 0.00% 0 IOSXE-RP Punt Qo
388 9 4 2250 0.00% 0.00% 0.00% 0 MCPRP RG Timer
389 0 2 0 0.00% 0.00% 0.00% 0 L2X Switching Ev
390 1 2 500 0.00% 0.00% 0.00% 0 VPWS Thread
391 7 98 71 0.00% 0.00% 0.00% 0 EVPN Mgr Thread
392 0 3 0 0.00% 0.00% 0.00% 0 EVPN Thread
393 2898969 22460297 129 0.00% 0.00% 0.00% 0 DiagCard1/-1
394 0 2 0 0.00% 0.00% 0.00% 0 PPP NBF
395 818624 56119606 14 0.00% 0.00% 0.00% 0 PfR BR Learn
396 0 2 0 0.00% 0.00% 0.00% 0 RBSCP Background
397 0 2 0 0.00% 0.00% 0.00% 0 ATIP_UDP_TSK
398 0 1 0 0.00% 0.00% 0.00% 0 Probe Input
399 0 1 0 0.00% 0.00% 0.00% 0 EVPN HA Bulk Syn
400 0 2 0 0.00% 0.00% 0.00% 0 STP HA IPC flow
401 0 1 0 0.00% 0.00% 0.00% 0 ac_atm_state_eve
402 0 1 0 0.00% 0.00% 0.00% 0 ac_atm_mraps_hsp
403 0 1 0 0.00% 0.00% 0.00% 0 ATM HA AC
404 0 1 0 0.00% 0.00% 0.00% 0 BFD HA
405 1 262 3 0.00% 0.00% 0.00% 0 CEM PROC
406 0 1 0 0.00% 0.00% 0.00% 0 CEM HA
407 0 1 0 0.00% 0.00% 0.00% 0 CEM HA AC
408 0 2 0 0.00% 0.00% 0.00% 0 PPPoE VRRS EVT M
409 1807217 109681438 16 0.00% 0.00% 0.00% 0 Inspect process
410 1 1 1000 0.00% 0.00% 0.00% 0 LICENSE AGENT
411 0 2 0 0.00% 0.00% 0.00% 0 URL filter proc
412 0 1 0 0.00% 0.00% 0.00% 0 VPDN CCM Backgro
413 0 1 0 0.00% 0.00% 0.00% 0 EVPN main thread
414 0 1 0 0.00% 0.00% 0.00% 0 NVE MGR RWATCH T
415 0 1 0 0.00% 0.00% 0.00% 0 VMATM Callback
416 1 2 500 0.00% 0.00% 0.00% 0 AN
417 0 1 0 0.00% 0.00% 0.00% 0 AN HELPER
418 0 1 0 0.00% 0.00% 0.00% 0 AN CONFIG DOWNLO
419 0 6 0 0.00% 0.00% 0.00% 0 AAA System Acct
420 0 1 0 0.00% 0.00% 0.00% 0 AAA HA
421 0 1 0 0.00% 0.00% 0.00% 0 AAA HA cleanup
422 1 1 1000 0.00% 0.00% 0.00% 0 DHCP SIP
423 0 2 0 0.00% 0.00% 0.00% 0 DHCPv6 LQ client
424 0 1 0 0.00% 0.00% 0.00% 0 IPv6 ACL RP Proc
425 0 1 0 0.00% 0.00% 0.00% 0 IPv6 Static Hand
426 2315899 5617215 412 0.00% 0.00% 0.00% 0 QoS stats proces
427 0 2 0 0.00% 0.00% 0.00% 0 BD MACSEC HA
428 0 2 0 0.00% 0.00% 0.00% 0 BD MACSEC HA CHK
429 0 1 0 0.00% 0.00% 0.00% 0 BD MACSEC Bulk S
430 0 2 0 0.00% 0.00% 0.00% 0 BD Route Msg Hol
431 0 1 0 0.00% 0.00% 0.00% 0 BD Route Rx Proc
432 0 1 0 0.00% 0.00% 0.00% 0 AC HA Bulk Sync
433 0 1 0 0.00% 0.00% 0.00% 0 AToM HA Bulk Syn
434 0 1 0 0.00% 0.00% 0.00% 0 AToM MGR HA IPC
435 0 1 0 0.00% 0.00% 0.00% 0 VFI HA Bulk Sync
436 0 1 0 0.00% 0.00% 0.00% 0 XC RIB MGR
437 0 1 0 0.00% 0.00% 0.00% 0 LDP HA
438 0 2 0 0.00% 0.00% 0.00% 0 TSPTUN HA
439 0 1 0 0.00% 0.00% 0.00% 0 RSVP HA Services
440 0 2 0 0.00% 0.00% 0.00% 0 TE NSR OOS DB Pr
441 0 2 0 0.00% 0.00% 0.00% 0 MPLS TP HA
442 1 2 500 0.00% 0.00% 0.00% 0 LFDp Input Proc
443 0 1 0 0.00% 0.00% 0.00% 0 MFI Comm RP Proc
444 0 1 0 0.00% 0.00% 0.00% 0 LFD Label Block
445 0 1 0 0.00% 0.00% 0.00% 0 Path set broker
446 10 69 144 0.00% 0.00% 0.00% 0 MVPN Mgr Process
447 0 2 0 0.00% 0.00% 0.00% 0 Multicast Offloa
448 0 1 0 0.00% 0.00% 0.00% 0 ONEP Dispatch po
449 0 1 0 0.00% 0.00% 0.00% 0 ONEP Dispatch po
450 0 1 0 0.00% 0.00% 0.00% 0 MRIB RP PROCESS
451 0 1 0 0.00% 0.00% 0.00% 0 MRIB RP Proxy
452 6509 184189 35 0.00% 0.00% 0.00% 0 MFIB Master back
453 277629 14039279 19 0.00% 0.00% 0.00% 0 FRR Manager
454 0 1 0 0.00% 0.00% 0.00% 0 BGP HA SSO
455 0 2 0 0.00% 0.00% 0.00% 0 MPLS VPN HA Clie
456 2085977 109681437 19 0.00% 0.00% 0.00% 0 TLSCLIENT_PROCES
457 0 1 0 0.00% 0.00% 0.00% 0 SSL background p
458 0 1 0 0.00% 0.00% 0.00% 0 Select Timers
459 0 2 0 0.00% 0.00% 0.00% 0 HTTP Process
460 1850 93625 19 0.00% 0.00% 0.00% 0 RECORD_LIC_PROCE
461 0 1 0 0.00% 0.00% 0.00% 0 EM Background Pr
462 0 1 0 0.00% 0.00% 0.00% 0 IDMGR CORE
463 0 1 0 0.00% 0.00% 0.00% 0 Key chain liveke
464 12073733 935532 12905 0.00% 0.01% 0.00% 0 BGP Scanner
465 0 3 0 0.00% 0.00% 0.00% 0 Crypto WUI
466 1 3 333 0.00% 0.00% 0.00% 0 EST Client
467 5 90 55 0.00% 0.00% 0.00% 0 DynCmd Package P
468 0 1 0 0.00% 0.00% 0.00% 0 EEM MLANG MANAGE
469 42829 2246985 19 0.00% 0.00% 0.00% 0 CRM_CALL_UPDATE_
470 29863421 877511381 34 0.07% 0.04% 0.05% 0 MMA DB TIMER
471 0 2 0 0.00% 0.00% 0.00% 0 Manet Infra Back
472 0 2 0 0.00% 0.00% 0.00% 0 AAA Cached Serve
473 0 2 0 0.00% 0.00% 0.00% 0 ENABLE AAA
474 0 3 0 0.00% 0.00% 0.00% 0 LDAP process
475 0 2 0 0.00% 0.00% 0.00% 0 LINE AAA
476 15 648 23 0.00% 0.00% 0.00% 0 LOCAL AAA
477 14108 102382 137 0.00% 0.00% 0.00% 0 TPLUS
478 0 19 0 0.00% 0.00% 0.00% 0 MPLS Auto Mesh P
479 0 1 0 0.00% 0.00% 0.00% 0 Opaque Database
480 2207696 109681438 20 0.00% 0.00% 0.00% 0 Timer Library
481 17342 582518 29 0.00% 0.00% 0.00% 0 Crypto Support
482 0 1 0 0.00% 0.00% 0.00% 0 IPSECv6 PS Proc
483 0 1 0 0.00% 0.00% 0.00% 0 EAP Process
484 11517 31207 369 0.00% 0.00% 0.00% 0 NIST rng proc
485 146892 8673735 16 0.00% 0.00% 0.00% 0 crypto engine pr
486 0 1 0 0.00% 0.00% 0.00% 0 RSA background p
487 1291 62427 20 0.00% 0.00% 0.00% 0 Crypto CA
488 0 3 0 0.00% 0.00% 0.00% 0 Crypto PKI-CRL
489 0 1 0 0.00% 0.00% 0.00% 0 Crypto PKI-Rev-P
490 0 1 0 0.00% 0.00% 0.00% 0 PKI OCSP
491 0 1 0 0.00% 0.00% 0.00% 0 PKI Revocation
492 0 2 0 0.00% 0.00% 0.00% 0 COND_DEBUG HA IP
493 0 2 0 0.00% 0.00% 0.00% 0 File Copy Handle
494 1 1 1000 0.00% 0.00% 0.00% 0 AAA Proxy
495 1 1 1000 0.00% 0.00% 0.00% 0 TPS IPC Process
496 0 2 0 0.00% 0.00% 0.00% 0 SEGMENT ROUTING
497 0 2 0 0.00% 0.00% 0.00% 0 SRMS_PROCESS
498 0 1 0 0.00% 0.00% 0.00% 0 LS LIB
499 0 2 0 0.00% 0.00% 0.00% 0 MMON PROCESS
500 1 1 1000 0.00% 0.00% 0.00% 0 DS0 PCM Capture
501 0 1 0 0.00% 0.00% 0.00% 0 QOS PERUSER
502 0 2 0 0.00% 0.00% 0.00% 0 PIM HA
503 44483888 97001072 458 0.00% 0.07% 0.06% 0 Crypto IKEv2
504 0 1 0 0.00% 0.00% 0.00% 0 IKEv2 AAA handle
505 0 1 0 0.00% 0.00% 0.00% 0 encrypt proc
506 20908 1304677 16 0.00% 0.00% 0.00% 0 CRYPTO MAP FREE
507 0 1 0 0.00% 0.00% 0.00% 0 Crypto INT
508 443700 14582701 30 0.00% 0.00% 0.00% 0 Crypto IKE Dispa
509 387756 658476 588 0.00% 0.00% 0.00% 0 Crypto IKMP
510 0 1 0 0.00% 0.00% 0.00% 0 IPSEC manual key
511 0 1 0 0.00% 0.00% 0.00% 0 IPsec vesen keym
512 1947862 8905220 218 0.00% 0.00% 0.00% 0 IPSEC key engine
513 0 1 0 0.00% 0.00% 0.00% 0 Crypto ACL
514 0 1 0 0.00% 0.00% 0.00% 0 Crypto PAS Proc
515 0 2 0 0.00% 0.00% 0.00% 0 GKM GM Process
516 0 1 0 0.00% 0.00% 0.00% 0 GKM KS PROCESS
517 0 1 0 0.00% 0.00% 0.00% 0 Licensing MIB pr
518 0 1 0 0.00% 0.00% 0.00% 0 dcm_cli_engine
519 0 3 0 0.00% 0.00% 0.00% 0 dcm_cli_provider
520 0 4 0 0.00% 0.00% 0.00% 0 DCM Core Thread
521 16557 294683 56 0.00% 0.00% 0.00% 0 EEM ED Syslog
522 1 4 250 0.00% 0.00% 0.00% 0 EEM ED Generic
523 0 4 0 0.00% 0.00% 0.00% 0 EEM ED Track
524 1 4 250 0.00% 0.00% 0.00% 0 EEM ED Routing
525 1 4 250 0.00% 0.00% 0.00% 0 EEM ED Resource
526 0 1 0 0.00% 0.00% 0.00% 0 Syslog Traps
527 0 2 0 0.00% 0.00% 0.00% 0 DiagCard2/-1
528 5 651 7 0.00% 0.00% 0.00% 0 BGP Consistency
529 0 2 0 0.00% 0.00% 0.00% 0 ICRM
530 0 2 0 0.00% 0.00% 0.00% 0 AUTO DEPLOY PROC
531 441861 5600977 78 0.00% 0.00% 0.00% 0 Flash low disk s
532 3 4 750 0.00% 0.00% 0.00% 0 BGP Event
533 0 1 0 0.00% 0.00% 0.00% 0 Online Diag EEM
534 615323 2808464 219 0.00% 0.00% 0.00% 0 SPA ENTITY Proce
535 0 2 0 0.00% 0.00% 0.00% 0 ISG MIB jobs Man
536 0 1 0 0.00% 0.00% 0.00% 0 SONET Traps
537 0 1 0 0.00% 0.00% 0.00% 0 Policy HA Timer
538 0 2 0 0.00% 0.00% 0.00% 0 ESG SPAN process
539 0 2 0 0.00% 0.00% 0.00% 0 MCPRP UTD Timer
540 340 4166 81 0.00% 0.00% 0.00% 0 AAA SEND STOP EV
541 0 1 0 0.00% 0.00% 0.00% 0 Test AAA Client
542 0 1 0 0.00% 0.00% 0.00% 0 IKEv2 FlexVPN Pr
543 0 1 0 0.00% 0.00% 0.00% 0 IKEv2 Cluster Lo
544 0 1 0 0.00% 0.00% 0.00% 0 BGP VA
545 1989 1069 1860 0.00% 0.00% 0.00% 0 DCM snmp dp Thre
546 0 3 0 0.00% 0.00% 0.00% 0 snmp dcm ma shim
547 162590 5617426 28 0.00% 0.00% 0.00% 0 Bulkstat-Client
548 0 3 0 0.00% 0.00% 0.00% 0 dcm_expression_p
549 164 4734 34 0.00% 0.00% 0.00% 0 EEM Server
550 5 18 277 0.00% 0.00% 0.00% 0 Call Home proces
551 0 1 0 0.00% 0.00% 0.00% 0 Call Home DS
552 0 1 0 0.00% 0.00% 0.00% 0 Call Home DSfile
553 0 3 0 0.00% 0.00% 0.00% 0 EEM Policy Direc
554 0 1 0 0.00% 0.00% 0.00% 0 ONEP Dispatch po
555 0 4 0 0.00% 0.00% 0.00% 0 EEM ED CLI
556 0 4 0 0.00% 0.00% 0.00% 0 EEM ED Counter
557 1 4 250 0.00% 0.00% 0.00% 0 EEM ED Interface
558 0 4 0 0.00% 0.00% 0.00% 0 EEM ED IOSWD
559 0 4 0 0.00% 0.00% 0.00% 0 EEM ED None
560 0 4 0 0.00% 0.00% 0.00% 0 EEM ED OIR
561 1 4 250 0.00% 0.00% 0.00% 0 EEM ED RF
562 0 4 0 0.00% 0.00% 0.00% 0 EEM ED SNMP
563 1 4 250 0.00% 0.00% 0.00% 0 EEM ED SNMP Obje
564 0 4 0 0.00% 0.00% 0.00% 0 EEM ED SNMP Noti
565 41324 1165815 35 0.00% 0.00% 0.00% 0 EEM ED Timer
566 0 4 0 0.00% 0.00% 0.00% 0 EEM ED Test
567 0 4 0 0.00% 0.00% 0.00% 0 EEM ED Config
568 0 4 0 0.00% 0.00% 0.00% 0 EEM ED Env
569 0 4 0 0.00% 0.00% 0.00% 0 EEM ED DS
570 0 4 0 0.00% 0.00% 0.00% 0 EEM ED CRASH
571 0 4 0 0.00% 0.00% 0.00% 0 EM ED GOLD
572 23005 111302 206 0.00% 0.00% 0.00% 0 Syslog
573 670401 5486853 122 0.00% 0.00% 0.00% 0 CENT EXPORTER TH
574 167894 5616552 29 0.00% 0.00% 0.00% 0 qos_mon_periodic
575 1 4 250 0.00% 0.00% 0.00% 0 EEM ED RPC
576 0 1 0 0.00% 0.00% 0.00% 0 IP SLAs ICMP Jit
577 0 1 0 0.00% 0.00% 0.00% 0 PM Callback
578 0 1 0 0.00% 0.00% 0.00% 0 ISSU Utility Pro
579 0 1 0 0.00% 0.00% 0.00% 0 IOSXE-RP Virtual
580 2 3 666 0.00% 0.00% 0.00% 0 WSMAN Process
581 0 1 0 0.00% 0.00% 0.00% 0 Online Diag CNS
582 0 1 0 0.00% 0.00% 0.00% 0 Online Diag CNS
583 0 4 0 0.00% 0.00% 0.00% 0 EEM ED Ipsla
584 0 1 0 0.00% 0.00% 0.00% 0 IP SLAs Ethernet
585 0 2 0 0.00% 0.00% 0.00% 0 DiagCard3/-1
586 0 4 0 0.00% 0.00% 0.00% 0 RBM CORE
587 1 3 333 0.00% 0.00% 0.00% 0 CTS credentials
588 9 3 3000 0.00% 0.00% 0.00% 0 VLAN Manager
589 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
590 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
591 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
592 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
593 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
594 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
595 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
596 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
597 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
598 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
599 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
600 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
601 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
602 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
603 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
604 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
605 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
606 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
607 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
608 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
609 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
610 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
611 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
612 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
613 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
614 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
615 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
616 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
617 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
618 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
619 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
620 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
621 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
622 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
623 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
624 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
625 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
626 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
627 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
628 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
629 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
630 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
631 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
632 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
633 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
634 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
635 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
636 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
637 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
638 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
639 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
640 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
641 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
642 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
643 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
644 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
645 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
646 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
647 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
648 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
649 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
650 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
651 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
652 0 1 0 0.00% 0.00% 0.00% 0 CWAN OIR IPC Rea
653 830005 3428594 242 0.00% 0.00% 0.00% 0 mdns Timer Proce
654 1 2 500 0.00% 0.00% 0.00% 0 MRIB Process
655 84 5339 15 0.00% 0.00% 0.00% 0 EEM Helper Threa
656 0 1 0 0.00% 0.00% 0.00% 0 ONEP Dispatch po
657 0 1 0 0.00% 0.00% 0.00% 0 ONEP Dispatch po
658 0 1 0 0.00% 0.00% 0.00% 0 ONEP Dispatch po
659 0 1 0 0.00% 0.00% 0.00% 0 ONEP Dispatch po
660 0 1 0 0.00% 0.00% 0.00% 0 ONEP Dispatch po
661 0 1 0 0.00% 0.00% 0.00% 0 ONEP Dispatch XD
662 0 1 0 0.00% 0.00% 0.00% 0 XOS async sync X
663 14403917 280597069 51 0.00% 0.01% 0.00% 0 ONEP Network Ele
664 4203968 64466443 65 0.00% 0.00% 0.00% 0 IP SNMP
665 3072296 32224426 95 0.00% 0.00% 0.00% 0 PDU DISPATCHER
666 8450483 34765144 243 0.00% 0.00% 0.00% 0 SNMP ENGINE
667 0 2 0 0.00% 0.00% 0.00% 0 IP SNMPV6
668 0 1 0 0.00% 0.00% 0.00% 0 SNMP ConfCopyPro
669 0 2 0 0.00% 0.00% 0.00% 0 SNMP Traps
670 24213 920641 26 0.00% 0.00% 0.00% 0 CENT_SPA
671 16427934 51821770 317 0.00% 0.03% 0.04% 0 CENT-BR-0
672 37530639 154445900 243 0.07% 0.10% 0.09% 0 CENT-MC-0
673 1 4 250 0.00% 0.00% 0.00% 0 MFIB_init
674 14924197 562731438 26 0.00% 0.01% 0.00% 0 IGMP Input
675 34197292 1234560996 27 0.00% 0.05% 0.06% 0 PIM Process
676 12217362 561744511 21 0.00% 0.00% 0.00% 0 Mwheel Process
677 0 1 0 0.00% 0.00% 0.00% 0 mcast_rw_process
678 4 64 62 0.00% 0.00% 0.00% 0 MRIB Trans
679 41415896 115681093 358 0.31% 0.08% 0.08% 0 NHRP
680 434863 5871640 74 0.00% 0.00% 0.00% 0 Multicast Replic
681 150341 7021467 21 0.00% 0.00% 0.00% 0 MFIB_rate
682 25 71 352 0.00% 0.00% 0.00% 0 MFIB_cable
683 63444575 2794987193 22 0.15% 0.12% 0.10% 0 MFIB_mrib_write
684 8 57 140 0.00% 0.00% 0.00% 0 MFIB_mrib_read
685 7380 391191 18 0.00% 0.00% 0.00% 0 MFIB_backwalk
686 0 3 0 0.00% 0.00% 0.00% 0 MFIB_ppr_release
687 444995 14042025 31 0.00% 0.00% 0.00% 0 MFIB_hw_stats
688 153732 2703645 56 0.00% 0.00% 0.00% 0 Tunnel Security
689 1351713 3845047 351 0.00% 0.00% 0.00% 0 Crypto SS Proces
690 1 1 1000 0.00% 0.00% 0.00% 0 SEP_webui_wsma_h
691 3404 50073 67 0.00% 0.00% 0.00% 0 BGP Task
692 0 1 0 0.00% 0.00% 0.00% 0 BGP BMP Server
693 0 61 0 0.00% 0.00% 0.00% 0 TCP Listener
694 0 1 0 0.00% 0.00% 0.00% 0 IPv6 Access Cont
695 2678966 56611207 47 0.00% 0.00% 0.00% 0 NTP
696 0 1 0 0.00% 0.00% 0.00% 0 EM Action CNS
697 1428446 25964176 55 0.00% 0.00% 0.00% 0 EIGRP-IPv4
698 1975283 65894101 29 0.00% 0.00% 0.00% 0 BGP Router
699 4675053 52245711 89 0.00% 0.00% 0.00% 0 EIGRP-IPv4 Hello
700 0 1 0 0.00% 0.00% 0.00% 0 SEP_webui_wsma_h
701 312937 3865582 80 0.00% 0.00% 0.00% 0 EIGRP-SFv4 Hello
702 4440483 117995907 37 0.00% 0.00% 0.00% 0 CENT_COLLECTOR_T
703 7219112 51052054 141 0.00% 0.01% 0.00% 0 CENT_COMMUNICATI
704 5 1 5000 0.00% 0.00% 0.00% 0 PKI Trustpool
705 318 15606 20 0.00% 0.00% 0.00% 0 SSH Event handle
706 0 1 0 0.00% 0.00% 0.00% 0 Network Synchron
707 58678 957904 61 0.00% 0.00% 0.00% 0 SASRcvWQWrk2
708 544 326 1668 0.00% 0.00% 0.05% 867 SSH Process
Was affected in the network performance last Monday.
Cristian
personally, you running some OLD code :
Cisco IOS XE Software, Version 16.09.02 (Bug also same train version 16.9.4)
suggest upgrading to the latest 17. X  code and checking.
BB
Leo Laohoo
What is the size of the WAN link?
What license features are enabled?
Post the complete output to the command "sh platform resources".
Hi Leo
WAN Link is 400Mbps
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 appxk9 Permanent appxk9
uck9 None None None
securityk9 securityk9 Permanent securityk9
ipbase ipbasek9 Permanent ipbasek9
The current throughput level is 1000000 kbps
**State Acronym: H - Healthy, W - Warning, C - Critical
Resource Usage Max Warning Critical State
RP0 (ok, active) H
Control Processor 0.91% 100% 80% 90% H
DRAM 2370MB(61%) 3878MB 88% 93% H
ESP0(ok, active) H
QFP H
DRAM 251583KB(47%) 524288KB 80% 90% H
IRAM 0KB(0%) 0KB 80% 90% H
CPU Utilization 37.00% 100% 90% 95% H
Cristian
That is abnormally high.
Post the complete output to the following commands:
  1. sh version (NOTE:  Remove the hostname and leave everything alone)
  2. sh platform software status con brief
  3. sh process memory platform sort location rp active (NOTE:  Do not post the entire output.  We want to see the "first page" of the output)
I strongly recommend upgrading to the latest 16.9.X.  Do not be tempted to load any firmware versions higher than 16.9.X.  Do not go, say, 16.12.X or 17.X.X.  Stick with 16.9.X.
mateus.provesi
@cristian.munoz did you got any solution?
I assume you are having the same, or a similar, problem ?
Yes, that's right.
