01-07-2004 06:36 AM - edited 03-02-2019 12:43 PM
If I am load balancing between two sites using OSPF and I add 3DES with GRE. Will I have any problems with my load balancing?
01-07-2004 07:05 AM
you should have no problems as long as you have your pipes costed the same .
01-07-2004 08:34 AM
I was always told that you cannot loadshare across more than one IPSEC tunnel. Was I told wrong?
01-08-2004 01:30 AM
If you are running IPSEC over GRE, and only have one GRE tunnel, and per destination load balancing, there will be no load sharing.
