Load Director and Database (SQL?)
jlantoona
Hi, I have a 416 Load Director. I was wondering if this can be used for a SQL database?
Can the 416 load direct any ports or is it only FTP, SMTP, DNS, Telnet, Web?
thisisshanky
Level 11
Level 11
SQL uses tcp and udp ports 1433 and 1434
So i think you should be able to load direct using the virtual and bind commands with appropriate ports specified. A sample would look like this
virtual 10.10.10.1:1433:0:udp is
bind 10.10.10.1:1433:0:udp 10.10.10.2:1433:0:udp
Hope that helps. Give it a try!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
