06-16-2004 11:54 AM - edited 03-02-2019 04:26 PM
I have two switch (2950) connected to one router (2FE) and the switches are connected between to other port too.
I can make a load sharing (balancig) the traffic to two switch towars the router.
What feacture are use?
Martín
06-16-2004 12:17 PM
I assume that the router interfaces connected to the switch will be in different subnets. So, this would mean that load-sharing thorugh the switch is dependent on the size of each subnet. If that is the case, you'll need to create 2 vlans on the switch and assign each vlan to the user9s) and router interface.
06-16-2004 01:29 PM
Hi robho,
The two switch have one route static to and virtual ip of the router.
06-16-2004 09:26 PM
Martin, I can surely help but please explain in detail with diagram so I know what you are trying to achieve.
Thanks.
RH
