Looking for topology help
maxmaxmax
I am new to setting up a routing infrastructure and I have a 2 part question...
1. I will be routing up to 3 vlans on 1 switch with a 1721 router. Can I configure virtual interfaces on the router, or do I need actual physical ethernet ports on the router that are physically connected to ports on my switch from each vlan?
2. In terms of topology, I currently have a flat network where my gateway is my firewall (no router). If I add the router in between my switch and my firewall, can I just change the ip of the firewall from being the gateway address that the router will then become, to be a node on one of my vlans?
Thanks.
3 Accepted Solutions
rwcrowe
1) You do not need to have a seperate physical interface in each VLAN for the router. You can use sub-interfaces for each VLAN. Below is an example, just look at the relavant section on configuring the external router for inter-vlan routing.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1826/products_configuration_guide_chapter09186a0080088102.html
http://www.cisco.com/en/US/tech/tk389/tk390/technologies_configuration_example09186a00800949fd.shtml
2) It would be easier to just assign the router as the default gateway for each subnet. Then the router will have a default route to the firewall.
Kanwar
you can do this if your router has fastethernet and the correct IOS. you can create sub interfaces on 1721 with fastethernet that link be a trunk link. so on the switch you have three vlans connected to the router with a trubk line. from there you can do a default route to the Firewall.
the 1721 supports 802.1Q (not ISL) inter-VLAN routing, so you do not need different physical Ethernet ports, you can configure the existing port as a trunk port and use virtual interfaces.
I guess configuring the firewall as a node on one of the VLANs will work, as long as there is a default route on the router pointing to the firewall...
Regards.
GP
rwcrowe
Kanwar
Regards.
GP
