monitor VRF's on c7200 (MPLS-VPN)
yosiz
does anyone found out how to monitor MPLS-VPN router ?
i have a 7200 router which has several VRF's in it which i would like to monitor (number of sessions per vrf , ip traffic..etc.) each vrf..
i found several links to the VPN-MIB and MPLS-VPN and PPVPN., but all talked about experimental and draft mibs... which didn't work on my router.
has anyone found the oid for inside VRF monitor ? (if any)
thanks
5 Replies 5
rmushtaq
Level 8
Level 8
Does mplsVpnVrfTable (.1.3.6.1.3.118.1.2.2) from MPLS-VPN-MIB of some interest here?
i already tried that.. but the router doesn't seem to return any info for that oid subtree...
though the IOS ver is fairly updated :
IOS (tm) 7200 Software (C7200-JS-M), Version 12.2(4)B2
Can you tell me the exact IOS image name from the 'sh ver' output?
c7200-js-mz.122-4.B2.bin
This IOS image does not have the MPLS-VPN-MIB present in the image, that's why you're not getting any reply back. Need to know what MIBs are in which IOS(tm) images? Send email to mii@external.cisco.com with a subject of "help" to find out how (Note: this is an automated list).
