Need Help on IP Sla configuration
ericeshun
I am configuring IP Sla on a Cisco 1700 series router with the commands below but I'm not able to add the Track keyword to the static route command-line
rtr 6
type echo protocol ipIcmpEcho 172.27.0.254 source-ipaddr 172.27.0.6
timeout 3000
frequency 900
exit
rtr schedule 6 life forever start-time now
track 6 rtr 6 reachability
exit
ip route 0.0.0.0 0.0.0.0 172.27.0.254 ????????(not able to add track 6)
take a look here and you'll see the first IOS image where this feature was introduced ( 12.3 and further) and that it is not supported on IPBase on 1700 routers.
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html
Regards.
Alain
cadet alain
could you post show version output .
Regards.
Alain.
Thanks. Below is the ouput of sh version.
IOS (tm) C1700 Software (C1700-SV8Y-M), Version 12.2(11)T8,  RELEASE SOFTWARE (f
c1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Sat 29-Mar-03 15:45 by hqluong
Image text-base: 0x80008124, data-base: 0x811377D8
ROM: System Bootstrap, Version 12.2(1r)XE1, RELEASE SOFTWARE (fc1)
OBU uptime is 1 day, 2 hours, 54 minutes
System image file is "flash:c1700-sv8y-mz.122-11.T8.bin"
cisco 1751 (MPC860P) processor (revision 0x300) with 52429K/13107K bytes of memo
ry.
Processor board ID FOC07260PEX (4052560654), with hardware revision 0000
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
2 Serial(sync/async) network interface(s)
2 Voice FXS interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Regards.
Alain
Thanks Alain.
Sorry I did not get back to this site in time. I was working on upgrading the IOS; however I have been having
memory challenges so I decided to come back here.
Unfortunately there is no solution.
Thanks for your response.
