Need IOS Help.
sagar.joshi
I am having
1> Two 6506 Back 2 Back connected. Having Hybridge IOS.
2> Nine 3508 at distribution.
3> 90 3512+3524+3548 Switches at access layer.
From last few days I have started facing high broadcasting problems. Is there is any Latest IOS which will help me in stoping the same.
My IOSs as follows:
1> At core :
L2 - cat6000-sup.6-2-2.bin
L3 - c6msfc2-psv-mz.121-7a.E1
2> At Distribution :
c3500XL-c3h2s-mz.120-5.4.WC.1.bin
3> At Access Layer :
c3500XL-c3h2s-mz-120-5.3.WC.1.bin
Thanks in Advance.
befthimi
Hello there. If you believe that you are observing higher broadcast traffic than expected, the the BEST course of action would be to find the source of this traffic. Otherwise, there is a 'broadcast suppresion' feature available in the CatOS software you are already running which will help prevent your switchports from being congested with broadcast traffic:
http://cco/univercd/cc/td/doc/product/lan/cat6000/sw_6_2/confg_gd/bcastsup.htm
Check the conig guide for the same feature on the other platforms.
However, I urge you to identify the source of the traffic first, so you ensure that you are not killing off legitimate traffic.
I hope this helps.
Bill.
