09-08-2004 11:12 AM - edited 03-02-2019 06:19 PM
What is the SNMP OID that supports get/set of the port duplex on a catalyst 4506 running IOS Version 12.1(20)EW2 ? Also, is there an OID that allows the port speed to be set (including auto)?
09-08-2004 11:41 AM
dot3StatsDuplexStatus from the ETHERLIKE-MIB.
09-08-2004 12:52 PM
That is a read-only OID. How do I set the duplex (and speed)
09-08-2004 04:30 PM
Check out:
.1.3.6.1.4.1.9.5.1.4.1.1.10.
Integer Values can be:
1 half
2 full
3 disagree (when the port was auto and it can't agree with host)
4 auto
.1.3.6.1.4.1.9.5.1.4.1.1.9.
Integer Values are the number of b/s of the port or 1 for auto. e.g. 100MB would be '100000000'
Dan.
09-09-2004 05:07 AM
Those OIDs are portDuplex and portAdminSpeed from the portTable MIB. Unfortunately, they are not supported by IOS on the catalyst 4500's.
