Network config problem
edgarferreira
Hi All
Hope you can help. I have a network problem conecting the switches together.
Here it is. I am connecting two switches through a les 100 mb link. One switch is a L2 swich and the other is a L3 switch. I have trunked them together using 8021q via ports on each switch. I am unable to ping the diferent networks on each side. This is how it looks like.
network1---switch1(L2)----les 100mb ----switch2----network2.
any ideas please.
thanks
Prashanth Krishnappa
Can you let us know what kind of switches they are and config from them and port numbers which connect the two?
