NM-1Fe card not recognised in 3620
brian_bosveld
We are getting a message:
MEMINIT: No iomem table entry for pa type 0xD7 in slot 1
When we boot with the card installed and do not see the interface at the console prompt.
Are we missing something.
Thanks for any help.
edangel
Please check your IOS version, I believe that the 12.1 & above should work and 12.2 version positively works since that is what is used in mine. Also may check what is amount of dram & flash. This message appears to be coming upon initial bootup, I once had to switch card slots on 2 cards(3620) just to make router bootup correctly. HTH Edward
