One port of 2950G attached to a hub is not forwarding,why?
cobra_he
Hello,in my network,a 2950G-24 switch is attached to a Hub,distance between them is near 100m,the connection port in 2950G-24 is configured to 10m and half -duplex.After a uncertain time,the port led is solid amber,status of the port is line down and protocol down.After re-plug out and in the cable,the port become ok.Why?can you tell me how to resolve this problem?Thanks.
Prashanth Krishnappa
Does the interface see lot of collisions? If so, the port might be error disabling. Can you paste the output of sh interface fastethernet 0/x
Following is the output on 2003/02/12 and 2003/02/24.
2003/02/12
FastEthernet0/26 is up, line protocol is up
Hardware is Fast Ethernet, address is 0009.b7ce.8e5a (bia 0009.b7ce.8e5a)
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive not set
Half-duplex, 10Mb/s
input flow-control is off, output flow-control is off
Last input never, output 00:00:01, output hang never
Queueing strategy: fifo
Output queue :0/40 (size/max)
25072 packets input, 5918241 bytes, 0 no buffer
Received 2620 broadcasts, 0 runts, 0 giants, 0 throttles
155221 packets output, 30164967 bytes, 0 underruns
4 output errors, 1478 collisions, 3 interface resets
0 babbles, 0 late collision, 1136 deferred
0 lost carrier, 0 no carrier
Following is the output on 2003/02/24.
2003/02/24
Keepalive not set
Half-duplex, 10Mb/s
Last input never, output 00:00:00, output hang never
314106 packets input, 37827763 bytes, 0 no buffer
Received 10300 broadcasts, 0 runts, 0 giants, 0 throttles
1230378 packets output, 628467177 bytes, 0 underruns
4 output errors, 38347 collisions, 3 interface resets
0 babbles, 0 late collision, 26217 deferred
