ospf routing path
bmehdi
Hi ,
we have three router connected to each other via frame-relay.My router is connected to the other two via frame-relay.problem is all the routes my router learns (of both router ) is from serial 1/0.1.
int serial1/0.1 point-to-point
ip address 10.1.1.253 255.255.255.252
ip address 10.1.1.249 255.255.255.252
ospf configuration is
router ospf 10
network 10.2.1.1 0.0.0.255 area 20(my router network)
network 10.1.1.240 0.0.0.15 area 0
show ip ospf neighbor identifies both the neighboirs in full state.
Any suggestions
16 Replies 16
deilert
Level 6
Level 6
according to above you have 2 s1/0.1 interfaces . For some reason it sees this as a more attractive router , are you using the ip ospf cost command or are you setting a bandwidth statement on the interfaces, Can you paste in a sh run
ruwhite
Level 7
Level 7
This can't be your configuration--as David has noted, you have tow s0/0.1's... If you typed this in this way, it would just change the ip address on the one subinterface. :-)
I don't see where you're tying the frame dlci's to the subinterfaces--maybe the router has both frame dlci's on one subinterface, or on the main interface (?). And, are you seeing this on the "hub" of the frame cloud, or the "spokes" of the frame cloud (just to make certain I understand your question correctly).
Russ.W
thanks for the response and sorry ,typo here ,actually the other serial subinterface is serial 1/0.2.And two PVC by dlci's are defined for each of the interfaces.
wanted to add another thing and that is the other two routers are learning routes from the routers attached to them.This is confusing,Any commands or hints ?
I hate to ask more questions, but.... Are you saying that both of the "spoke" routers are learning all their routes only through the "hub" router on the frame cloud? If so, that would be natural, really, since there's no PVC between the "spoke" routers directly.
Is this what you are seeing, or are the routes not learned on the "hub" router?
Russ.W
Np,questions are welcome,following is the flow maybe it will help
ROuterA --pvc--RouterB--pvc-routerC
----------pvc--------------
My router is RouterB ,my router is learning routes of router A and C from router C.While router A is learning my routes from me,and router C's routes from C.Same is the case with router C.
Does this make sence.
It could be that the cost of the pvc B-C is lower than the cost of B-A-C. Please send the output of the sh ip ospf interface for all 6 PVC interfaces,
Ian
router A and C are also connected and have a pvc.
following is the show ip ospf and show ip neighbor output at my router
sh ip ospf
Routing Process "ospf 20" with ID 10.20.1.1 and Domain ID 0.0.0.20
Supports only single TOS(TOS0) routes
Supports opaque LSA
It is an area border router
SPF schedule delay 5 secs, Hold time between two SPFs 10 secs
Minimum LSA interval 5 secs. Minimum LSA arrival 1 secs
Number of external LSA 0. Checksum Sum 0x0
Number of opaque AS LSA 0. Checksum Sum 0x0
MSCLHR#sh ip ospf neighbor
Neighbor ID Pri State Dead Time Address Interface
10.21.1.1 1 FULL/ - 00:00:32 10.1.254.250 Serial1/0.2
10.22.1.1 1 FULL/ - 00:00:34 10.1.254.254 Serial1/0.1
my router shows routes learned by 10.1.254.254 only via serial 1/0.1
sh ip ospf
Supports opaque LSA
at my router.
sh ip ospf interface s1/0.1
Serial1/0.1 is up, line protocol is up
Internet Address 10.1.254.253/30, Area 0
Process ID 20, Router ID 10.22.1.1, Network Type POINT_TO_POINT, Cost: 48
Transmit Delay is 1 sec, State POINT_TO_POINT,
Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
Hello due in 00:00:07
Index 1/1, flood queue length 0
MSCLHR#sh ip ospf int s1/0.2
Serial1/0.2 is up, line protocol is up
Internet Address 10.1.254.249/30, Area 0
Process ID 20, Router ID 10.21.1.1, Network Type POINT_TO_POINT, Cost: 48
Index 2/2, flood qu
Could you do a:
show ip ospf data router 10.21.1.1
? That would tell us what the local router has received from this neighbor on its router LSA. If you know of some route which is attached to 10.21.1.1, could you capture a show ip route for that route?
Russ.W
here are the outputs,my router id is 10.23.1.1,as you can see the 10.21.1.1 is learning routes from both routers while my ip route learn just from 10.22.1.1
sh ip ospf database
OSPF Router with ID (10.21.1.1) (Process ID 30)
Router Link States (Area 0)
Link ID ADV Router Age Seq# Checksum Link count
10.21.1.1 10.21.1.1 128 0x8000060D 0x5D51 4
10.22.1.1 10.22.1.1 127 0x80000734 0xF9CD 4
10.23.1.1 10.23.1.1 158 0x8000011F 0xCC0D 4
Summary Net Link States (Area 0)
10.22.0.0 10.22.1.1 636 0x80002DA1 0x5D38
10.21.1.0 10.21.1.1 159 0x8000009C 0xCFF4
10.21.2.0 10.21.1.1 159 0x8000061A 0xA36B
10.23.1.0 10.23.1.1 1346 0x80000101 0xEF6D
10.23.2.0 10.23.1.1 1346 0x80000101 0xD05A
Summary ASB Link States (Area 0)
10.21.11.1 10.21.1.1 175 0x8000061A 0x6A3C
Router Link States (Area 30)
10.21.1.1 10.21.1.1 190 0x80000C1F 0x4F8E 18
10.21.11.1 10.21.11.1 336 0x8000583F 0x38A3 5
Summary Net Link States (Area 30)
10.22.0.0 10.21.1.1 141 0x80000002 0xE916
10.22.254.244 10.21.1.1 135 0x80000003 0x45C9
10.22.254.248 10.21.1.1 181 0x80000001 0x6C7F
10.22.254.252 10.22.1.1 135 0x80000003 0x774F
10.23.1.0 10.21.1.1 161 0x80000001 0x14C8
sh ip route
Gateway of last resort is 10.21.254.246 to network 0.0.0.0
10.21.0.0/24 is subnetted, 19 subnets
C 10.21.191.0 is directly connected, Serial
C 10.21.190.0 is directly connected, Serial
10.22.0.0/16 is variably subnetted, 4 subnets, 2 masks
C 10.22.254.244/30 is directly connected, Serial3/1.1
C 10.22.254.248/30 is directly connected, Serial3/1.2
O IA 10.22.0.0/16 [110/98] via 10.22.254.246, 00:03:10, Serial3/1.1
O 10.22.254.252/30 [110/161] via 10.22.254.246, 00:03:10, Serial3/1.1
10.23.0.0/24 is subnetted, 15 subnets
O IA 10.23.158.0 [110/237] via 10.23.254.249, 00:03:10, Serial3/1.2
O IA 10.18.159.0 [110/181] via 10.23.254.249, 00:03:10, Serial3/1.2
According to your sh ip rou you are getting routes from s3/1.1 and 1.2 so I don't see the problem you described of getting routes from only one neighbor. Would you please help me understand this?
This output is of the other router thats getting the information as it should .
mine is not.
Okay, so could you post the output of show ip ospf data router 10.21.1.1 and show ip ospf data router 10.22.1.1 from your router? I don't see the actual database from your router anyplace on the thread (?).
Thanks!
Russ.W
