06-06-2004 11:55 PM - edited 03-02-2019 04:12 PM
Hi there!
A customer of ours have a problem with their Catalyst 4500-SUPII+, they are having one customer on each physical-if and then they use service-policy to limit the traffic.
The problem is that they reach a limit after about 96 interface's, the log reports this:
-4-ACLHWPROGERRREASON: Output Policy Map: 10Mbps - out of hardware TCAM entries.
*Jan 1 09:37:08: %C4K_HWACLMAN-4-ACLHWPROGERR: Output Policy Map: 10Mbps - hard
ware TCAM limit, qos being disabled on relevant interface.
The interface configurations looks like this:
switchport trunk native vlan 67
switchport trunk allowed vlan 67,416
switchport mode trunk
duplex full
service-policy input 10Mbps
service-policy output 10Mbps
tx-queue 3
priority high
shape 1000000 bps
spanning-tree portfast trunk
In regards to access-lists they are using vlan access-maps to minimize the usage of TCAM entries (but it doesn't help, still the same problem);
vlan access-map kunder 10
action drop
match ip address test
vlan access-map kunder 20
action forward
match ip address all
vlan filter kunder vlan-list 67
ip access-list extended all
permit ip any any
ip access-list extended test
permit tcp any any range 135 139
permit udp any any range 135 netbios-ss
permit udp any any eq 445
permit tcp any any eq 445
deny udp host 172.16.20.1 eq bootps any
permit udp any eq bootps any
So then question: Is there any way to minimize and simply this further, to be able to use QoS on every interface? + which good show commands can we use (most of the TCAM related ones doesn't work on the SUPII+)?
Thanx ahead!
/Peter Ahremark
CCIE #8680
06-07-2004 01:11 AM
try and increase the TCAM size, I do not know if this command works on the 4500 though:
Switch(config)# sdm access-list 8192
With the command:
show internal all-regions
you can verify how much space is available in TCAM.
HTH,
GP
06-07-2004 10:47 PM
First of all a big thanx for your quick answer!
I'm sorry to say though, that neither of these two commands works, they don't exist on a SUPII+ in a 4500 :-(
I have had the thought before about increasing TCAM, but we didn't find any "SDM" commands sadly....
Any other ideas ???
Thanx ahead!
/Peter
07-09-2004 05:33 AM
Hi.
I hope you have solved your problem, but I have had the same. And I found the solution in this:
mls aclmerge algorithm {bdd | odm}
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/sw_5_3/msfc121e/msfc.htm#1047404
Saying this knowing that I have a Cat6K and yours is a Cat4500.
Hope this helps.
07-15-2004 12:37 AM
Hi there!
Thanx for your reply. Well I actually opened up a TAC-case in regards to this situation.
And we also ended out in looking on ways to optimize, but sadly it's not possible to switch between BDD and ODM on a 4500 box, that's only available on the 6500.
So we have basically given up this, the 4500 isn't really suitable if you want to do policers on all interfaces + some acl's, at least not to the extent that our customer wants...
Anyway, thanx a lot for your reply, great that it solved itself for you!
Greetings from Stockholm, Sweden!
