packet was less than 2 bytes
anatsira
We have a router 2621 (MPC860) on which runs the ios 12.0(4). When connection Isdn BRI is activated, we have this message:"%pquicc-1-toosmall: pquicc[0/0], packet was less than 2 bytes"
what does that mean? and if it is a problem, is there a solution?
Thank you
raarons
Saw this recently on a customer's 2620. Tied up to bug CSCdw90765 or CSCds51025. Resolved by upgrade to 12.2(12).
Hope this helps.
cpapilaya
Make sure that you have all the requirements to connect to ISDN BRI, for your router 2621 you may purchase network module (NM-4B-U) for four-port ISDN BRI or NM-8B-U for 8-port module. Don't forget to assign switch-type for your connection, ask your provider to get correct switch-type, without this correct switch-type you may experience wierd error command. Also make sure you assign correct SPIDs, again get this number from your provider. Hope can help..
