Physical Dimensions: Distance Between Ethernet Jacks on the Cisco WS-2960X-48TS-L
DMorgret
   I want to make sure that the special RJ45 connectors that I am considering will fit side-by-side on a Cisco switch.  What is the physical distance between ports on Cisco switches, or this switch in particular?
5 Replies 5
mkazam001
Level 3
Level 3
distance between switch ports on most switches is about 2mm
regards, mk
That doesn't sound right.  The backshell of my RJ45 is 14mm wide.  Looking at photographs, the distance can't be much different from that, either way.
you asked about the distance between the ports :)
the port itself should be 10mm wide
regards, mk
r_m
As you can see from the picture below the distance is about 2.10mm.
Greetings
precision of language when seeking assistance
not a problem though ;)
regards, mk
