Please help me to design with routing
nahidh527
Dear All,
I am a beginners of Cisco Support Community. I had tried to design a routing system form CCNN2 books example. I had already succeed to build routing some of these. But I could not connect three Server in a 2811 router via vlan1 switch card. Basically I tried to config ip but failed. And my another problem is to config wifi in 2811 router. I attach the task doc.
So. I need your help to complete this task. I hope you will not avoid me.
Nahid
Joseph W. Doherty
Did you configure a SVI on the 2811 for VLAN 1?
