PPP/SLIP connection
sklenda
I have a cisco AS5400. When I connect to the cisco over modem (without running ppp) it gives me immediately prompt "Username", it doesn't wait untill I press Enter as it was working on cisco AS5200. Does anyone know what to set to start it working?
Probably due to this problem my SLIP connection doesn't work. Thank you.
makchitale
Level 6
Level 6
Remove "autoselect during-login" command from the line configuration.
conf term
line x y
no autoselect during-login
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fdial_r/drfacas.htm#wp1024524
Thanks, Mak
