Problem to create an Interface Virtual-Template
mciarlo
We create two interface Virtual Template. The interface virtual template are in status DOWN. Why this in this state? The configuration required a keepalive?
Router A (C1750 - 12.1.5t9):
interface Serial0
mtu 1600
bandwidth 128
no ip address
encapsulation frame-relay IETF
load-interval 30
service-policy output llq-2v
down-when-looped
cdp enable
frame-relay traffic-shaping
frame-relay lmi-type ansi
interface Serial0.1 point-to-point
bandwidth 1
frame-relay class voice
frame-relay interface-dlci 17 ppp Virtual-Template1
interface Serial0.2 point-to-point
bandwidth 128
frame-relay interface-dlci 18 ppp Virtual-Template2
interface Virtual-Template1
mtu 1600
bandwidth 32
ip unnumbered Loopback1
ip accounting output-packets
ip tcp header-compression iphc-format
load-interval 30
max-reserved-bandwidth 100
ppp multilink
ppp multilink fragment-delay 10
ppp multilink interleave
ip rtp header-compression iphc-format
interface Virtual-Template2
mtu 1600
bandwidth 128
ip unnumbered Loopback2
load-interval 30
ppp multilink
Router B (C7200 - 12.3(9)):
interface ATM5/0.159 point-to-point
description Sucursal 159 Rio Cuarto ATM
mtu 1600
bandwidth 256
ip access-group atlanta out
no ip proxy-arp
pvc 0/159
vbr-nrt 128 128
oam-pvc manage
encapsulation aal5snap
protocol ppp Virtual-Template7
interface Virtual-Template7
description Sucursal 159 Rio Cuarto template
mtu 1600
bandwidth 256
ip unnumbered Loopback159
load-interval 30
ppp multilink
ppp multilink fragment delay 10
